03 Maxima shut off while driving.. Why?!
Hey guys. So today I was driving and my 5.5 gen maxima 6mt shut off while driving. Never happened before. I realized it when my steering wheel when hard. I put it on N and it started right up again and kept driving like normal. Any ideas on what could have caused this?
I have had the stalling issue with my Max a couple of times before I actually got a P0345 Bank 2 CPS error code, I replaced my Bank 2 CPS (with an OEM sensor) aftermarket ones are unreliable. There is a TSB recall on our Max's for the CPS (best to check with your dealer and see if your Vin. was part of the recall and possible check if yours have been replaced. I suppose you may have an issue with your MAF (seems like all engine mishaps tend to get blamed on the MAF). Get your car scanned to see if you have any pending codes that have simply not lit up the SES light.
Did the car display any other issues prior to stalling out ie. car would not go up past 2500 rpm, or did it just up and die while in motion?
I have had the stalling issue with my Max a couple of times before I actually got a P0345 Bank 2 CPS error code, I replced my Bank 2 CPS (with an OEM sensor) aftermarket ones are unreliable. There is a TSB recall on our Max's for the CPS (best to check with your dealer and see if your Vin. was part of the recall and possible check if yours have been replaced. I suppose you may have an issue with your MAF (seems like all engine mishaps tend to get blamed on the MAF). Get your car scanned to see if you have any pending codes that have simply not lit up the SES light.
And no, the cars been running like a champ since I got it, no issues until this. I was going around 40mph, popped it off gear approaching a red light, next thing you know it was off
I had the exact same thing as the OP happen to me last night. Car shut off while driving. Luckily I was on a local residential street and was able to let it roll to the side. OBD pulled P0420 and P0340. The P0420 has been there for a while but the P0340 was new. So does this mean that the issue was most likely caused by the MAF sensor? If so, is it worth trying to clean it first and seeing if that helps? How much do they cost brand new and is there a good place to purchase them online?
Hit the junkyard or buy a used one from an org'er here.
Oem is the only way to go with the MAF.
You don't want to know the new price.
Used should be $60 shipped or less off the org.
Junkyard is around $30 at my local yard.
Cleaning is worth a try, but it likely needs replaced.
Someone on here told me that there was a recall CPS sensors on 5.5 gens. I was gonna replace mine but first changed the MAF and its been fine
I think you test the MAF by disconnecting it while the car is runnung. If it shuts off, the MAF should be fine
I have had a similar problem. My car would shut off when backing off from heavy throttle. When I would change out of 6th gear into neutral when getting off the highway, it would die.
A regular spark plug change, CPV valve, injector cleaner,and other regular 100k maintenance solved the problem.
Oh and cleaning the throttle body. Mechanic said that an overall tune up would do the trick and it did. However, my idle slightly went up after doing all of this maintenance. I assume the car wasn't getting enough fuel when changing out of gear into neutral and died. Now my car has a much better throttle response and acceleration too
So there are two CPS in the car. I'm trying to figure out which one I need. The code i'm getting is P0340: Camshaft Position Sensor "A" Circuit (Bank 1 or Single Sensor)
Looking at the diagram, do I need part code 23731M or 23731MA?
http://www.nissanpartszone.com/Page_...ponentsIndex=1
I assume this is relatively simple to do. I change the oil and have changed the in cabin microfilter and ignition coils but thats the extent of my experience. Is there a how-to available somewhere?
It is not complicated to do and if you've changed coils then you can change the CPS.
Disconnect battery
Remove intake piping at throttle body
Bank 1 CPS is located under the throttle body on the side of the head just below the valve cover.
Unplug CPS
Remove CPS which is held on by one 10mm bolt
Install new CPS carefully and be sure not to damage or dirty the sensor side
Plug it in and button everything else back up and you should be done.
Side note, make sure you do not attempt to open the throttle body using your hand. This can ruin your throttle unit.
For bank 1, you need 23731MA. It is the rear bank closest to the firewall.
Disconnect battery
Unplug CPS
Disconnect battery
Unplug CPS
Also, are ebay parts legit? I found this: http://www.ebay.com/itm/NEW-Cam-shaf...-/360500317567
Not sure if it is OEM or not but price is really low so i would guess not.
No, I mean don't move the throttle valve at all. There is no reason to mess with it for this job anyhow so it shouldn't be a problem, just wanted to give fair warning in case while it was open and available you became curious as to the cleanliness of the inner area of the throttle body. I'm speaking from experience here. Lol.
That eBay part is no different than any part you would get from rockauto or OReilly or the like except that the eBay one doesn't tell you exactly what brand it is. Just says aftermarket. Avoid that for sure.
Picture didn't work, at least not on my tablet, which defaults to the mobile view but it normally has no problem with pictures. I'll switch to the regular desktop view and see if it shows up. Otherwise try uploading it again if you would.
EDIT: I recommend going to rockauto for the part. Find the Hitachi brand as that is the OE manufacturer for Nissan on that part. In the description, you're looking for the part labeled for the right side. Right = Bank 1, Left = Bank 2. Should be about $40-50, if I remember correctly.
I had same issue was the maf sensor it would pop a cel because it was a ghost code I took it to dealer ship. They replaced knock sensors and tb still acted the same , I bought a used maf n problem resolved mine would die or stall when I would go to neutral before a stop , check for ghost code first
I've got everything out but I can't get the connector to disconnect from the sensor. I've pushed the green clip in till it clicks and per this video:
at the 1:20 mark, the sensor is supposed to just pop off the clip but it won't for me. I've tried using all the strength and jiggling it a bit but nothing works. What gives!
Hondarydr
Dec 30, 2024 06:15 PM
erniel
Aug 8, 2015 09:32 AM
