2000 Nissan Maxima o2 Interchangeability.
Old Apr 16, 2014 | 09:14 PM
Sternzy's Avatar
http://www.rockauto.com/catalog/rafr...rttype=5132&ck[ID]=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=n7a1rihitc1alm2ghqd18hjk31
What do you guys think about using BOSCH Part # 13504 Fed. spec upstream o2 sensor in a Cali. spec car for both front and rear banks?
The reason I ask is I tried soldering an extension and the silver o2 wire wasn't taking solder at all, the copper wire I used didn't seem to help either. Then I tried crimp connections and they didn't seem to work either.
The car has 145k on it so I figure it's time for new sensors anyway. This one claims to be 76" long and would obviously remove any headaches if it is compatible. It's also only $60.79 at Rock Auto.
If not I was considering just getting stock new o2 sensors and cutting the harness wrap back some like I've read around here.
Old Apr 17, 2014 | 11:41 AM
FanaticMadMax's Avatar
they are not interchangeable, you need to look under the hood decal where the emission label is and it will say if it's a Fed Spec or CA spec. Additionally you have to know which O2 sensor you're replacing since there are four of them, bank one sensor one, bank two, sensor sensor one, which is before the cat, or as they call it downstream. and there's bank one sensor two which is after the cat converter, which is know as upstream, same with bank two sensor two.
Old Apr 17, 2014 | 02:56 PM
DennisMik's Avatar
Fed spec and Cali spec are not the same sensor for bank 2.
Bank 1 is the same for both
Bank 1, sensor 1 (upstream)
22690-2Y921 1999.04-2000.06 FED VQ30DE
22690-2Y921 1999.04-2000.06 CAL. VQ30DE
Bank 2, sensor 1 (upstream)
22691-2Y901 1999.04-2000.06 FED. VQ30DE
22691-3Y101 1999.04-2000.06 CAL. VQ30DE
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
niZ
Aug 7, 2015 10:18 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
