Aftermarket LEDs Grounding Point??
Old Jun 3, 2014 | 06:07 PM
E1974's Avatar
Hello all......any suggestions would be awesome! Im trying to install some after-market LED strips in my interior (under dash). I cant get a good ground. Any suggestions for a grounding point?
If you think under the door trim (at the base of the door) would be a good spot, please suggest the best way to remove the trim. I kinda tried to remove it, but it seemed to not want to budge. I didnt want to break anything, so I stopped and came in here to post.
Thanks!
Old Jun 3, 2014 | 06:46 PM
Ghozt's Avatar
if you look directly to the left of the fuse box on the inside, theres a screw. i took this screw off and used a ring terminal inbetween the plastic and the body (metal) and its been working great
Old Jun 3, 2014 | 06:48 PM
E1974's Avatar
Sweet...Ill give that a shot. Gracias!
Old Jun 3, 2014 | 07:56 PM
E1974's Avatar
That worked perfectly! Thank you.
Old Jun 4, 2014 | 07:39 AM
assiduous's Avatar
I'm thinking about this as well, since this kit that the dealer sells is 500$ installed.
What did you use for power? I don't want to strip a random 12V wire. Can you get a pic of the connection by any chance? Much appreciated - thanks
Old Jun 4, 2014 | 09:59 AM
Ghozt's Avatar
i used an add-a-fuse and plugged it into the fr.power socket fuse. that one turns on with the car. the other power socket fuse is on all the time; either are good depending on what you're doin
Old Jun 4, 2014 | 02:16 PM
assiduous's Avatar
wow. this is the first time I hear of add-a-fuse. Feel embarrassed. Beautiful solution.
pktaske
May 6, 2016 07:49 AM
ac max 92
Sep 17, 2015 07:35 AM
pktaske
Sep 4, 2015 08:40 AM
