Climate control
Old Jun 10, 2014 | 11:46 AM
davidrae's Avatar
Climate control
Installed aftermarket stereo and now I have to turn on climate control manually everytime I start the car. Never had to do that before. The first two times I took out the stereo no problem now not so good. Just a hassel not life ending.
Old Jun 10, 2014 | 11:51 AM
njmaxseltd's Avatar
Is the clock and your new stereo also loosing memory? Check fuses, make sure the connections into the climate control unit are all tight.
Old Jun 10, 2014 | 11:53 AM
JoshG's Avatar
could be the wires and fuses behind it, I had best buy install a aftermarket radio in my car, once i got it back my A/C would not turn on at all, I told them "I cannot live without A/C and it was working perfectly fine before, so can u fix it please" and they took 15 mins to fix it, all they said was one of the wires were placed in the wrong place.
Old Jun 10, 2014 | 05:37 PM
davidrae's Avatar
It does work you just have to turn it back on everytime. It also reads 75 degrees until you turn the temp down to 68
Old Jun 10, 2014 | 10:59 PM
DennisMik's Avatar
Pull the control unit out and inspect the wire harness connectors that they are plugged in all the way. Also carefully inspect each wire in the connectors that they have not been pushed out of the plastic connector.
Old Jun 11, 2014 | 01:26 PM
asand1's Avatar
After I installed my stereo last weekend my mode switch lights on my manual HVAC weren't working. Rather than temp fate and make things worse I will leave well enough alone.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
