Exhaust a little louder..
Hey guys, When I got the Max, I planned on performance mods right away... When it came to exhaust I wasn't going to do anything. I decided that I would at least do just mufflers and Y-Pipe. For the first time I heard my car while following a friend who was driving it, and I hear almost nothing. Is there some thing I can do to make it a little louder without getting a full cat back? anything with the cats?
Start by removing the resonator and see what you think. If you want a little more also change just the muffler to a greddy or magnaflow. Ofcoarse everyone has their own preference but I found thrush mufflers were a good bang for the buck so to speak and are well built and been around since the muscle car era and sound pretty good.
I don't believe it should throw any codes but it will make it a little louder giving you the sound your probably looking for. Might be worth a try. You could always put the resonator back in if your not happy with it. Are you still running stock pipe? If so you may want to go about 2 and a half inch but if your not wanting to go with larger pipe or headers removing the resonator is probably your best bet i would think.
I think I'm gonna go this route.. Is the 3"x"18 good for the stock piping or is your set up different?
-If my stock piping is 2.5", why do guys get 3"?
-is 18" exactly for our cars, or is it just the length they decided to go with?
Little nervous about too loud, or raspy
At the most I would go 3" for the mid-pipe and 2.5" aft.
is this right? I see resonators to quiet the exhaust sound..
http://www.ebay.com/itm/OBX-18-SUV-W...384532&vxp=mtr
If you are looking for a little more noise, a less restrictive resonator will increase the sound. If you cut out your resonator, you'd get way more sound and, possibly, drone.
That's what resonators do - quiet the sound. Intake resonators send intake air through baffles to quiet intake whoosh and exhaust resonators do exactly the same thing.
How do I know which ones are more or less restrictive?
Ok, so is it safe to say any aftermarket resonator is better than stock?
Now if someone can can tell me the exact size to get.. for my stock piping.. I got a few different sizes from you guys. Is 18" length 2.5 in and out, what I should be looking for?
My old Accord 4 banger had about a ten pound giant block of plastic intake resonator that, when removed, not only opened up the engine's breathing, but made the car sound much angrier.
When you get aftermarket intakes, they either replace or bypass the stock intake resonator, just like on the exhaust side.
As for which resonators are less restrictive and give more sound, sorry - I don't have a clue. I'm sure someone on these boards has a suggestion or two...
how loud or quiet do you want to make it.
You have 28" of length and 8" of space where the factory one was. Anything smaller will fit.
The longer, and larger the diameter, the more it will muffle.
I think 4" is fine, and any length between 16-20 and you should be happy.
If you drive a lot, or really don't want it that loud, then go with the 5 or 6" diameter.
Awesome, I'm looking for just a little more noise, nothing huge.. just something to compliment the mufflers with stock pipes.
Well I went with the 4x22 (as recommended by the tech at magnaflow) and the only notable increase in sound is inside the car (little more drone). out side sounds almost identical... If I go with 4x18 would it make the cabin noise worse?
Round is better for sound, at least they are generally louder than ovals of the same size. A smaller muffler will give you more noise and vice versa. That's all the info you really need on a muffler.
A resonator doesn't necessarily add/lessen sound. it really just changes the wave patterns will will alter how it comes out and this lessen drone.
