misfires but without check engine light
My 2002 Maxima SE automatic developed a habit after a valve cover gasket was replaced. It misfires randomly mainly when the engine is warm. It is noticeable only in idle. After a long drive the misfire is severe and drops the idle rpm to half. There is no check engine light. The dealer cannot find any problem code and returned the car with the same symptoms without doing anything. Two ignition coils had been replaced with Nissan coils about 2K miles ago, the two non-accessible ones. The spark plugs have about 10K miles on them. I am at the end of possibilities... and so apparently the dealer. Somebody mentioned possible dirt in the camshaft control?
Any ideas?
Any ideas?
The check engine light works when I first start. I also assume that the dealer diagnostics would have detected that. Compression checks should be done, but I hesitate because of the high cost of removing the intake manifold. The general performance of the car, i.e., acceleration and gas mileage is as usual in the past.
Thank you for the tip about checking the harness. I'll request that when I bring the car back to a shop. The misfiring is getting worse and much more frequent (still no check engine light), especially after a longer drive. Idle rpm drops to about 300 when it starts. When I raise the rpm to about 1000 the misfires goes away. I never encounter misfires at higher speeds. I am thoroughly lost....
Thanks to all of you!! You are great! The check engine light finally showed up yesterday and indicated that coil 5 was bad. The dealer had checked it about a week ago and found it to be fine.... I hope that will fix the problem...
CorollaULEV
30
08-09-2021 08:11 PM
Justinmc760
08-23-2015 03:10 AM
maxinout93
08-20-2015 02:17 AM
