What rpm should an auto idle at?
Old Jan 22, 2002 | 07:15 PM
josh95se's Avatar
After cleaning my throttle body..my car idles at 1250 in park and 750-800 in Drive...abit high?
Old Jan 22, 2002 | 07:33 PM
WaarrEagle's Avatar
Re: What rpm should an auto idle at?
Exact same thing happened to me. I adjusted my idle with a dirty TB and after I cleaned it I was idling above 1k. It should be 700 or so. Just unplug your TPS and adjust the idle screw until you hit 700. Its covered in the manuals you can buy.
Old Jan 23, 2002 | 06:13 AM
njmaxseltd's Avatar
Re: Re: What rpm should an auto idle at?
Set it at 800 with TPS unpluged. You get about a 650 rpm idle in D with absolutely no vibrations. Very smooth idle.
Old Jan 23, 2002 | 06:47 AM
Synki's Avatar
In "D" i idle at about 650rpms and its smooth. When im in "P" or "N" i am @ about 800rpms.
Old Jan 23, 2002 | 09:28 AM
Cumalot's Avatar
My idle is pretty weird too. At startup, it's at about 1k. After the car warms up though it get back to normal about 600. I haven't clean the TB yet though. The car drives normal so I don't think I should mess with it. I will clean my TB this weekend, I will see if this will do anything, if any, to the idle.
Old Jan 23, 2002 | 09:43 AM
jayanth's Avatar
the idle speed is bound to increase as soon as you clean your TB.After 2 weeks or 150 miles it comes back to normal.This is due to the normal wear in your TB and butterfly/plate valve.
Miket2006
Mar 1, 2021 03:55 AM
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
