Bent rim, repair or replace?
Old Mar 1, 2015 | 03:48 PM
00 Max's Avatar
After having my wheels balanced one ended up being bent on the inside, so it was put on the right rear. I have a small but noticeable shimmy at highway speeds. Local places can straighten it for around $40 (I think with a hammer). I'm sure when I ask if it will still shake on the highway they will say no. Will it ride smooth with a quality repair or should I just buy another rim? Thanks.
00 Max SE
Old Mar 10, 2015 | 12:19 AM
carlem9's Avatar
The shop that balanced your wheels should be able to tell the severity of the bent. If it is really minor, try to fix it first.
Old Mar 10, 2015 | 04:47 AM
00 Max's Avatar
Thanks for the reply, that's exactly what I did and the rim is fried.
Old Mar 17, 2015 | 02:38 PM
MaximaDrvr's Avatar
Steelies, alloy, or aftermarket and how bent it is would influence the answer.
$40 isn't much if it fixes your problem, but I would get a guarantee on that work if the wheel isn't round. As I was once told, "you can balance an egg, but doesn't mean it will roll well."
Old Mar 17, 2015 | 03:01 PM
00 Max's Avatar
I found out my egg rolls like frankinstein. Time for a new one.
FlaMark
25
Aug 28, 2015 10:15 AM
scarletsosa
Aug 17, 2015 09:09 PM
Samedi
Aug 12, 2015 01:54 AM
