power steering return hose substitute?
Hi Guys...power steer return hose out of production...guys at the shop say they take the old hoses and try to match them up with existing hoses in stock (from other models cars)...are able to make it work most often???
The pressure hose still in stock...it is the return hose on a 94 gxe that is out of stock.
I got an aftermarket power steering hose for my max a few years ago; I'm pretty sure it was the pressure hose. It wasn't as good as the Oem hose, fwiw. Steering wheel would not be able to turn as fast with the power steering pump "keeping up" (and keeping turning effort at the steering wheel low). But if the Oem hose is no longer available, I would guess there are probably still aftermarket hose options available at least. An aftermarket power steering hose is a better alternative IMO than an Oem hose that leaks power steering fluid.
Did you try checking courtesy nissan online?
Hi guys...the matching up present hose to an alternative in stock hose was a no go. However they did find the specific hose need from another dealer in another state.
ac max 92 ... courtesy nissan online...Thanks for the resource!
Thanks Guys !
Thanks Guys !
lowpost99
Oct 26, 2025 06:53 PM
