Low idle/ oil light flickering.
Old Jun 4, 2015 | 03:19 PM
intimidator's Avatar
When the engine is cold and I start the car the engine rpm would go to 400rpm and then the oil light would flicker and then rpm would go up to 500rpm.When I stop a stop light the rpm would drop to 400 the oil light would flicker again. I don't know what could be the problem.
Old Jun 4, 2015 | 03:34 PM
DennisMik's Avatar
Maybe the throttle body needs cleaning, maybe the MAF is going bad.
Is the check engine light on?
Old Jun 4, 2015 | 03:50 PM
The check engine light has not come on.
Old Jun 4, 2015 | 05:10 PM
NeedForSpeedGuy's Avatar
when was the last time you changed your oil? the vg engines run really hot and are known to burn oil.
Old Jun 4, 2015 | 06:03 PM
Fakie J Farkerton's Avatar
This is the 4th gen section. VQ.
Old Jun 4, 2015 | 08:20 PM
PH98I30's Avatar
My engine has never burned oil nor run hot with 143K on it.
Old Jun 4, 2015 | 08:24 PM
Its been about 5000 miles since my last oil change. Is the vq engine known to burn oil or were you talking about the vg engines?
Old Jun 5, 2015 | 03:45 AM
dwapenyi's Avatar
Vq35 yes oil consumption....Vq30 (yours) not soo much. The oil pump is chain driven so at very low rpms (below 500 rpm) you should expect the oil light to come on. The idle speed IIRC is 700-750 rpm for a manual tranny VQ30.
That cold, low idle could mean you need to clean your throttlebody.
Old Jun 5, 2015 | 07:32 AM
M in KC's Avatar
And clean your IACV. No doubt it is carbon fouled as well. Use specifically formulated TB cleaner not just any 'ol carb cleaner so as not to remove the finish off the butterfly other parts etc. You need a minimum idle speed to drive many thing: oil pump, trans pump if an auto, alternator etc.
And yeah my '97 doesn't burn a drop of oil, (leaks some) and never ran hot a day in life. It just rolled 350K last month. Amazing motors the VQ's. 7-800 rpms ought to get you where you need to be after a cleaning. Great How-To's in the How-To section. Easy Saturday morning project.
Old Jun 5, 2015 | 10:33 AM
JvG's Avatar
JvG
Your idle speed is too low. The oil pressure increases with engine speed, up to a point. Increase idle speed to specifications. Your engine is fine.
Roymg
Sep 3, 2018 05:10 AM
tnewbs
Aug 28, 2015 10:15 AM
maxinout93
Aug 20, 2015 02:17 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
