Dvd bypass with navigation
Old Jun 22, 2015 | 04:58 PM
Tommy6905's Avatar
I just got thru reading a bunch of threads but most consist of 09-11 maximas, before I start tearing the dash apart I have a few questions. Correct me if Im wrong:
Parking brake wire: pink/white
Vss wire: green/white
Ground parking brake wire and add toggle switch for the vss wire? Is this correct?
If this is going to turn into a project or mess something up with the navigation I won't even attempt it, some feedback is greatly appreciated
And last the car in question is a 2014 sv with navigation and tech package
Old Jun 22, 2015 | 08:52 PM
1996blackmax's Avatar
Yes, ground parking wire & toggle for VSS wire.
Old Jun 23, 2015 | 02:18 AM
Tommy6905's Avatar
Great, Now when the toggle is engaged do you lose all function of the gps?
Old Jun 23, 2015 | 05:22 PM
It will not function correctly as the car "will not" be moving. You will be able to actually input new directions. Very handy when you have a passenger that can input the information. Then switch it back & you're good to go.
Old Jun 23, 2015 | 05:57 PM
Tommy6905's Avatar
Thank you sir, seems simple enough. kindve stupid that the brake needs to be engaged to watch something or you need to pull over to input for gps. I know it's against the law but one solution maybe in the future would be to input a sensor into the passengers seat like the air bag sensor.....letting the system know someone else can input selections etc
Far fetched but an idea
Old Jun 23, 2015 | 07:01 PM
Maxgig's Avatar
Tommy, set aside a few hours to do it. Because of my bad eyes I had a hard time trying to find the right wire with the purple stripe. Due to that it took me about 5 hrs. But it was well worth it. When I take my nieces and nephew's to Sonic we watch a movie while we eat.
Old Jun 23, 2015 | 07:28 PM
Thank you sir, seems simple enough. kindve stupid that the brake needs to be engaged to watch something or you need to pull over to input for gps. I know it's against the law but one solution maybe in the future would be to input a sensor into the drivers seat like the air bag letting the system know someone else can input selections etc
Sure thing
Yeah, having a sensor on the passenger's seat would be nice. Why should you have to pull over when a passenger can input the address.
I wore my reading glasses
Old Jun 23, 2015 | 07:43 PM
Tommy6905's Avatar
Thanks for the advice, I sure will.
Old Jun 25, 2015 | 11:05 AM
CubbieBlue28's Avatar
Does anyone have a picture of what it looks like once working? Can you plug an external hard drive into the USB port to stream movies?
Old Jun 26, 2015 | 09:01 AM
mikekay's Avatar
I dont have GPS but have the color screen and inputs, I technically wouldn't require the switch correct, only part that stops working is the MPG sensors correct but other than that Im good? 2012 SV no nav/no bose
05' MaximaMan
Oct 8, 2017 06:36 PM
Fbana41
Aug 29, 2016 12:18 PM
worldwiderecognized
Sep 30, 2015 01:16 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
