97 Maxima - stall, idle, hesitation
Hello all,
My 97 Maxima (117K) was recently serviced for a p1447 code (wound up being charcoal canister) and a p0600. Dude found out the vehicle speed sensor cluster (?) connecting to ECU was bad, but would only cause speedometer to fail.
So, not I have a new problem (started happening before service) where the car will buck or hesitate while cruising on the highway, and stalls often when I am sitting at idle - at low speeds there is obvious hesitation in the transmission(?) shifting of gears. It feels like something isn't "catching"
Mecahnic cleaned TB and IACV lately, so I don't think those are the issue. I am thinking it could be MAF - any other thoughts?
rev the motor from the throttle cable under the hood, unplug maf while doing it, if nothing changes when you unplug, maf is your issue, try cleaning before replacing it, they can be expensive and jy mafs cab be hit or miss, especially if the vehicle you pull it from has heavy front end damage
Great, thanks! Also, the Overdrive light (OD orange) flashes at times when I start the car - do you think this has anything to do with the drivability issues, or is it probably to do with the VSS cluster I mentioned in the first post?
Okay, folks. I re-soldered the three electrical contacts on the MAF circuit board to the piece that connects to the wiring harness - all three were loose. Just took a test drive around my neighborhood (all under 40 mph) and all was great. I'm hoping this fixed it! I'll let you know what happens. . . thanks for all the advice!
Finkle
Sep 27, 2015 09:53 PM
doobadoo
Aug 15, 2015 06:43 PM
