which rims?? Im torn between these two
Old Aug 2, 2015 | 03:57 PM
brichi's Avatar
need opinions, Im torn between these two, both 20x8.5
Old Aug 2, 2015 | 04:44 PM
Nihon7GM's Avatar
I personally like the second one. The question I have would be which route you trying to go? You want to look more shine and looks/VIP'ish? or you want more of an tuner feel? From the picture the second one looks matte a gives more of a modified tuner image. The first one looks more for those who just buy the car get tint and throw rims on it and call it a day or they go for the whole lowered life with chrome trim. Both look good though, but my answer is the second one=).
Old Aug 2, 2015 | 04:45 PM
ABOMBZ's Avatar
First option Polished looks clean. make sure to get 40 series tires
Old Aug 2, 2015 | 04:53 PM
brichi's Avatar
Thanks guys. I love the 2nd one too but the 1st one pops more. Not sure which route yet.
The tires that were linked with them were 235/35/20. Would that work instead of the 40?
Old Aug 2, 2015 | 05:03 PM
ABOMBZ's Avatar
Too thin in my opinion. I have 40 series on mine and looks great and rides nice.
Old Aug 2, 2015 | 05:11 PM
lexcitement's Avatar
More info please....
what color is your car? like someone else said are you going for the tuner look or the VIP? Attention getter I'd say the first one, something out of F&F then go the 2nd route lol. More info would help though.
Old Aug 2, 2015 | 05:16 PM
Blaxima's Avatar
Second, the darker ones.
Old Aug 2, 2015 | 05:31 PM
brichi's Avatar
good call, definitely going 40
im going more for the modded, dropped look, want to lower it next and so on
Old Aug 2, 2015 | 06:21 PM
MaximaDrvr's Avatar
A 245/35/20 would be a better tire size choice.
It keeps the speedometer accurate and is the correct up size tire.
Old Aug 3, 2015 | 05:17 AM
brichi's Avatar
i like this size, whats the first number? 225, 235, 245?
Old Aug 3, 2015 | 09:28 AM
MaximaDrvr's Avatar
The first number is the tire width. You shouldn't go narrower than the factory equipment in my opinion.
The second number is the aspect ratio. That is the sidewall height as a percent of the width.
A 255/35/20 has the same height as a 235/40/20, but narrower tread.
Old Aug 3, 2015 | 10:38 AM
BassAddictJ's Avatar
i vote shinier. option A (but in 40's)
Old Aug 3, 2015 | 02:20 PM
brichi's Avatar
so 245/40/20 may be the sweet spot then, 245 is the factory size now
Old Aug 3, 2015 | 03:47 PM
Max2013's Avatar
My choice would definitely be the second one. As you can tell with the split vote there won't be a clear cut preference from this group . Let us know what u decide!
Old Aug 3, 2015 | 05:31 PM
assiduous's Avatar
second one looks nicer. If you over 30 I vote for second. If you in 20s, i guess the shine may impress same age friends.
I have 225x50x17 tires. Big wheels will cost you lots of power and MPG. Already the 245mm on 18 " is too much for this car. This is a sacrifice where performance is thrown to gargage for looks. with 20s... you ain't gona be jumpin nobody at the traffic lights.
Old Aug 3, 2015 | 05:34 PM
MaximaDrvr's Avatar
No, the sweet spot is 245/35/20, which would be the factory correct plus size.
245/45/18
245/40/19
245/35/20
See the pattern?
Old Aug 4, 2015 | 05:06 AM
brichi's Avatar
oh nice, thank you for the info
Old Nov 13, 2015 | 05:21 PM
brichi's Avatar
will i have issues with the following rims?
NICHE - MISANO Anthracite
20x9 all around,
5x114.3
+25 offset
Old Nov 13, 2015 | 05:39 PM
MaximaDrvr's Avatar
They will poke just a little at stock height.
They will fit though.
Old Nov 13, 2015 | 05:43 PM
brichi's Avatar
sorry, what do you mean "poke"? Im a noob to all this, LOL
if you mean poke out from sides then how would the height effect it?
Old Nov 13, 2015 | 06:56 PM
MaximaDrvr's Avatar
Yes, the edge of the wheel will stick out 2-4mm past the fender. That is called poke.
Mild poke is what you are looking at. Some people get wheels that poke much more, then stretch the tires so the tread stays inside the fender.
When you lower a car, the wheels are pulled in closer to the body.
The control arm is a fixed length. As you lower the car, the angle of the arm increases, and it's horizontal axis measurement decreases.
Old Nov 13, 2015 | 07:13 PM
brichi's Avatar
ahhhhh, gotcha. thank you!! so i should look for a smaller offset maybe?
Old Nov 13, 2015 | 07:29 PM
Maximam's Avatar
How about the 20x10 with the 40mm offset. That is the size I am getting next.
Tire will be 255/35/20 square.
Old Nov 14, 2015 | 03:30 AM
MaximaDrvr's Avatar
10et40 fit fine. A 255 is a bit stretched. A 275/30/20 would give you a vertical sidewall, but it is a more expensive size.
Higher offset. You want between 30 - 35 with a 9" wide wheel at stock height.
Old Nov 14, 2015 | 06:40 AM
Maximam's Avatar
275 won't be happy on the front and I like to run a square setup on FWD.
Old Nov 14, 2015 | 11:50 AM
MaximaDrvr's Avatar
275 is fine on the front. It is what I run right now all the way around.
Old Nov 14, 2015 | 01:22 PM
Propa Teknique's Avatar
Those look nice. I like the first ones. Has anyone thought about adding the SR wheels from the 2016 Max to our 7th gen? Someone was willing to sell me theirs for a steal but I don't know how they would look on a Pearl White 7th Gen. I don't believe his are chrome.
Old Nov 14, 2015 | 08:56 PM
Maximam's Avatar
275/30 with a 20x10 40mm on Eibachs won't rub even cornering under compression up front? I need a size that won't rub even full compression in a corner.
Old Nov 14, 2015 | 08:59 PM
Maximam's Avatar
I would not, too narrow and too small of a diameter for my taste.
Old Nov 15, 2015 | 06:31 AM
brichi's Avatar
not too big of a fan of those, looking really into the ones i posted, only reason i added the 3rd one half way down was my concern in rubbing when turning and of i did 20x10, how do i get them without poking out.
im assuming +25 offset means they are pushed out further then no offset. Im new to all this and never dealt with "offsets" on rims
Old Nov 15, 2015 | 12:35 PM
MaximaDrvr's Avatar
Lower offsets will stick out further than high offsets. Et0 will stick out 25mm farther than et25 if the wheels are the same width.
Old Nov 15, 2015 | 12:36 PM
MaximaDrvr's Avatar
I'm on coils, so I can't answer with eibachs. But I'm lower than with eibachs and have no issues. I'm running a 9.5 with 275s.
Old Nov 15, 2015 | 02:44 PM
brichi's Avatar
20x10
5x114.3
+40
so that should work all around without them sticking out really?
Old Nov 15, 2015 | 06:41 PM
MaximaDrvr's Avatar
Yes.
Old Nov 15, 2015 | 07:11 PM
Maximam's Avatar
Your offset?
Old Nov 15, 2015 | 07:22 PM
maximase86's Avatar
I love lamp.
20x9 in front, 20x10.5 in the rear. No rubbing issues:
Old Nov 15, 2015 | 07:29 PM
Maximam's Avatar
You appear to be running a 245/35 on a 9, same as my current setup. My question is will a 20x10 on 40mm and 275/30 not rub up front even at full compression and cornering.
Old Nov 16, 2015 | 03:24 AM
MaximaDrvr's Avatar
9.5 et38 275s all the way around.
Running 1 finger gap ride height in the front and tucking tire in the rear.
Old Nov 16, 2015 | 08:31 AM
Maximam's Avatar
Great thanks.
Old Mar 10, 2016 | 06:06 PM
brichi's Avatar
Im narrowed down to
20x9 front - 245/35/20
20x10 back -
not sure what tire size to put on back, suggestions?
also offsets? lowered with Eiback prokit
