1992 maxima running rough black smoke
I am trying to troubleshoot my buddys 1992 maxima vg30e it is running really rough has a bad missfire at idle and clears up alittle when reved above 2500 rpm, also lots of black smoke coming out of exhaust. I disconnected the maf and it idled much better and no black smoke with maf unpluged what would cause this? No cel light, could it be the injectors or maybe the ecu? The ecu was replaced like 10 years ago. Already tried replacing maf with a new one and ran the same. what could cause this it is running rich alot of black smoke? All help is appreciated Thanks
Could be running lean. Not enough fuel. The injectors are notorious on the 3rd gens especially seeing it's a 24 yr old car. Try taking a multi meter and check the resistance on the injectors. Each injector should be 10-14 ohm though there is one under the left side of the upper intake manifold under the bend that you wont be able to test without taking off the intake manifold but for starters try checking all the others if they are out of spec. change the ones needed or for piece of mind being you'd have the upper intake off change em all. There is a member in the classifieds that has a used set with the rail up for sale but personally i'd go all new if your going to do the job. That is ofcoarse if that's your problem. Try pulling the spark plugs aswell to see what the signs are for which cylinders are causing the problem. Running better when pulling the maf harness sounds pretty strange to me though.
You are checking resistance across the injector pins with car off. Unplug the connector from the each injector, set your meter to ohms, and read across the injector pins - should read between 10 - 14 ohms. Tons of postings on here on how to do it.
Checked a few injectors a few showed 13.5 and one showed 23.5 ohms. It looks like a pita to change the injectors, what i still cant figure out is why the car idles almost perfect with maf unplugged
only thing is with maf unplugged car wont rev past 2k rpm's. I have been starting the car like that for a few days without a problem.
only thing is with maf unplugged car wont rev past 2k rpm's. I have been starting the car like that for a few days without a problem.Last edited by ac max 92; Sep 10, 2015 at 09:46 PM.
kjlouis
Nov 24, 2018 06:09 AM
