Performance Chip/ECU upgrade needed?
Old Sep 23, 2015 | 07:51 PM
Dasmith's Avatar
Hi, I have a 95 Maxima SE that I did a little work on, I added a cold air intake and a y-pipe to it (it runs and sounds great). I was under the impression that these particular upgrades don't have their full effect unless the ECU is programmed (via performance chips) to handle all the increased air to and from the engine. 1.) Do I need a chip for the engine to make my existing upgrades worth their money? 2.) Would a performance chip be worth the time and money?
I only know basics about performance chips, I don't know if they're all they're cracked up to be.
Old Sep 23, 2015 | 07:59 PM
No such thing as a performance chip for the Maxima (and most cars...the products out there are snake oil)
What you need is either JWT to tune your ECU, Nistune to tune it (and give you the ability to tune it yourself), or a Greddy Emanage Ultimate so you may do all the tuning yourself. Items 2 and 3 will also require a wideband gauge, and knowledge of tuning.
Personally, I'd go for option 2 or 3.
Old Sep 23, 2015 | 08:18 PM
Dasmith's Avatar
I see, I'll check into those options. In terms of performance, would one of those options give any real performance/efficiency changes? Or is it an upgrade that costs big money for small changes?
Old Sep 23, 2015 | 08:28 PM
IMO, the cost of the parts and/or tuning far exceeds the power gains. With proper tuning, I imagine you could pick up another 20hp. Only you can answer if it's worth it to you. But, if you continue to modify and climb the horsepower ladder, you can keep on tuning and keep on extracting just a little bit more power with each mod.
asand1's Avatar
Small changes. To really make horsepower you will need to swap cams, bump compression, or go forced induction. Simply supplying more air won't do much unless the engine can actually use it.
smplyamzng
Dec 13, 2015 01:19 PM
Dasmith
Aug 25, 2015 10:15 PM
TonyJr
Aug 20, 2015 12:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
