Selecting the firmness of Koni rears
I am trying to determine how firm I should set the Koni's I have in the rear with the non-adjustable Tokicos up front. What would be the best setting to compliment the front firmness. What would be the equivalent to the Tokicos up front? Thanks for you help in advance...
Re: Selecting the firmness of Koni rears
I had full soft, then reset it to 80% firm. I thought it just mad the back too stiff so I reset it to about 25%... and that's where it will stay... If you autocross then you may want it firmer... Get the fronts if you can... (AGX's are cheaper and don't require modification)
Re: Re: Re: Selecting the firmness of Koni rears
Originally posted by Mishmosh
Unless you want more understeer, it is a good idea to keep the back at least as firm as the front.
Also.. unless you go near full hard... the compression rate isn't changed ... it's mostly rebound.
I also have the Stillen RSB, which is 1 inch behind the axle beam. I would prefer to have the ride as comfortable as possible but dont want to loose performance. Would keeping the Koni's soft, but moving the RSB to under the axle beam keep my ride soft without producing too much understeer?
Thx
Thx
Thx
Thx
I didn't notice an overall improvement on reducing the floatiness or better handling with the back set high. All I really noticed was increased ride harshness...So i set it lower. I also have the RSB.
Thanks all for your help, I'm going to try the softest setting, use that as a baseline and then increase the stiffness as necessary for comparison. I appreciate all your help, I might also follow Cheston's suggestion and move the RSB under the axle beam from 1 inch behind to reduce some of the understeer. Thanks again!
ef9
Sep 5, 2015 11:18 PM
