1991 Maxima misfiring or something weird.
1991 Nissan maxima V6 Auto. been having this issue for a while now and keep trying to fix the possible issues and nothing is helping at all. the car starts right up no issues, but idles a little rough like a miss. give it any throttle while driving and it has no power and sounds like a miss, slow as *****. BUT one rps get around 3K the engine instantly smooths out and pulls like a dream. then it will shift and rpm drops below 3K and runs like crap again. been trying to figure this out for months. here is a list of parts rerplaced: plugs, plug wires, rotor, rotor cap, coil, ignition control module, O2 sensor, MAF sensor, cleaned IAC and EGR. I dont believe it is a fuel issue since it runs great at WOT above 3K. I checked for vacuum leaks with Ether and no jump in rpms. the check engine light doesnt come on, but the computer shows a code 33 for the O2 sensor but it is new. seems at almost any throttle position above 3K it runs great, anything under 3K (even WOT) it runs like crap. I am running out of options.....
Try taking a multi meter just to see if they are between 10-14ohm. Sounds like otherwise you've covered a fair bit of ground. Also i noticed no mention of the TPS you could also try testing it as per the FSM and if you are getting a code for the o2 maybe try checking the circuit as it may not necessarily be the sensor itself. I've heard if the o2 gets dropped it can be affected too.
I had a feeling that was your issue. I take it you did test the resistance on the injectors? What i did after taking everything apart on more than one occation i finally just decided to swap my lower intake and fuel rail to the 94 style which has much better connectors and went with a new set of 6 injectors and just did everything one time. Glad to hear everything worked out and your max is now running well.
Randy
Apr 7, 2016 10:07 PM
daillcyruz
Jan 14, 2016 05:34 AM
