Just got a 2000 maxima and I love it but have a few issues
OK so I bought a 2000 see for 500 runs and drives fine has a lot of miles but for 500 bucks I can't complain but of course with that I have a few issues when I bought the car it needed an alternator so I replaced that but still a battery and brake light pop up after about 3000 rpm witch I fixed bad ground but that brings Me to another set of issues I'm pretty sure that the gauge cluster is fried I've checked every fuse I can thinks of and more and nothing is this a common issue? It runs and drives great but seeing that I cannot tell engine temp it worries me it's only throwing one code speed sensor but I think this may be due to gauge malfunction any help would be great and please don't flame me lol I'm new the car
First thing first. How do you determine the gauge cluster is fried? Since is any of the gauges working, such as gas gauge, tach and so on...? as far as the temp gauge goes. two possibilities such as is it showing past the middle point, then your thermostat is stucked closed, which would be overheating, if the gauge not moving at all, then it could be a temp switch, that acts as a sending unit. and for the speed sensor, then that's probably why your speedometer on the cluster is not registering it. The speed sensor is so easy to replace which is mounted on the tranny on the driver side, however, you did not indicated if it a auto or manual? Hope this will guide you to the right direction to remedy the problem
Thx for the reply the cluster is completely dead I get nothing the lights work but no rpm fuel speedometer it won't show the miles it's an auto trans the rpm somtimes jump from 0 to 1 lol oh and the temp gauge moves every nowband then when you first turn the key..
kirkhilles
Jan 27, 2016 06:25 AM
shoot and any other sensors you could stuff in your pocket
