Brake Lights Not Working
Old Dec 27, 2015 | 09:55 AM
Colly3's Avatar
Hey all - suddently my braake lights are not working at all. All other lights are working as normal. Changes bulbs (no change) and checked driver side fuse (good) with no luck.
I am thinking maybe the ignition switch.. for about the last 2 months when i use my auto car start - put the key into the ignition and turn to on i can still remove the key without ther car turning off - have to use my remote to turn the car off on short trips. Longer trips >10 mins the car will recognize the key and lock the doors and the security light will stop flashing. Brake lights still do not work though, so maybe not.
Thanks in advance for your help.
Old Dec 27, 2015 | 02:59 PM
DennisMik's Avatar
The brake lights are completely separate from the ignition switch, so don't waste your time with the ignition switch.
The brake light circuit is very basic and simple: battery => fuse # 10 => brake light switch => light bulbs => chassis ground.
So either the brake light switch is bad or you have a broken wire or your auto start system is screwing up.
I place my bet on the auto start system screwing up.
Old Aug 16, 2017 | 08:17 PM
nissan99's Avatar
got the same problem so check the fuse it was blown .. so I change it still no brake light ? Check fuse again it's good , everything works tail lights headlights but no brake light .. possible brake switch so how do you change it out ? Any pics thanks
Old Aug 17, 2017 | 06:49 PM
saig's Avatar
Before you replace the brake switch, you may want to check the connector M15 next to brake switch or the sub-harness M4/B1 little down from the brake switch connector. M4/B1 is probably behind the driver's left kickplate based on the image. It could be loose. If your fuse is burnt again, it indicates a short within that stop lamp circuit.
Attached Thumbnails Brake Lights Not Working-brakelamp.png   Brake Lights Not Working-brakelamp-subconnector.png
Old Aug 17, 2017 | 07:20 PM
bryan163's Avatar
I had this problem before. I tested and the switch behind the brake pedal. Sure enough, it was bad. Replaced it, and got my brake lights back.
Old Aug 17, 2017 | 08:59 PM
nissan99's Avatar
Yea I did replace the fuse and step on the brake no brake lights , so check the fuse again it's good .. next switch and see
Tequila
Dec 6, 2015 08:29 PM
blkmax1
Nov 20, 2015 09:19 PM
BETO6700
Nov 10, 2015 09:54 AM
tre28bor
Oct 30, 2015 05:54 PM
Heat0212
Oct 28, 2015 06:33 PM
