10 things I hate about my 5th gen
Old Apr 16, 2016 | 07:20 PM
rvamax's Avatar
This is a common subject discussed in automotive related videos on YouTube and I think it would be fun to see what issues you have with your 5th gen, I'll start.
1. It's an automatic.
2. My brake rotors are warped and cause steering wheel vibration during high speed braking.
3. My 5th gen is a California compliant car.
4. My hood latch is a little lose and I can see movement at highway speeds with a head wind.
5. The steering wheel is not perfectly aligned with the wheels.
6. The steering wheel is too large.
7. My car stereo will, on occasion, switch from fm to am for no apparent reason.
8. I have only averaged 17mpg combined.
9. The rubber gasket, for lack of a better term, around my gear selector has lifted up at one corner.
10. There is a small chip in my windshield directly in front of the drivers seat, visible only after detailing the windshield.
Old Apr 16, 2016 | 07:44 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Reccomendations: 6th gen bbk, new hood stops, new maf, new radio (stock is rubbish)
Me? Rear rust, beam rear end, picky on CVs
Old Apr 16, 2016 | 07:49 PM
mclasser's Avatar
Many things can cause poor mileage on an older car. Start with proper tire pressure, new air filter, tune up and some fuel cleaner like Techron.
As far as the other stuff -- Replace the windshield, brakes, get an alignment.
Old Apr 16, 2016 | 08:20 PM
rvamax's Avatar
I'm having difficulty findings hood stops, do you have a link? What should I expect from a new maf, assume I know nothing.
Old Apr 16, 2016 | 08:22 PM
rvamax's Avatar
How much fuel cleaner should I use to expect a noticeable improvement in fuel economy?
Old Apr 16, 2016 | 08:25 PM
cornholio's Avatar
in no particular order to try and get this thread back on track
1. driver seat is ripped
2. 4x4 mode
3. not a 5.5
4. seatbelt dirty af
5. going to need tires soon
6. dents/dings/scrapes/
7. shifter trim/other plastics are all wonky/goo'd up
8. maximas are boats
9. dat stock stereo
10. dat stock everything
Old Apr 16, 2016 | 08:38 PM
cornholio's Avatar
http://charlottenissanparts.com/niss...partcode=62840
i have a similar hood vibration so i'm ordering 2 of these. i'll let you know if it works out.
Old Apr 16, 2016 | 08:43 PM
cornholio's Avatar
slightly cheaper if yo ufind them on nissanpartsasap.com
Old Apr 16, 2016 | 09:21 PM
george__'s Avatar
rear calipers
knotchy MT
solid rear beam
cv boot woes
turn radius
Old Apr 16, 2016 | 09:38 PM
cornholio's Avatar
Originally Posted by george__
rear calipers
knotchy MT
solid rear beam
cv boot woes
turn radius
tendency to rear-end people?
Old Apr 16, 2016 | 09:47 PM
Itz Shak's Avatar
1. REAR CALIPERS
2. REAR CALIPERS
3. REAR CALIPERS
4. Turn Radius a bit
Can't think of anything else so
Rear calipers 5-10.
Old Apr 16, 2016 | 10:08 PM
mclasser's Avatar
I'd start from one bottle and see how that goes.
Old Apr 16, 2016 | 10:11 PM
mclasser's Avatar
Originally Posted by Itz Shak
1. REAR CALIPERS
2. REAR CALIPERS
3. REAR CALIPERS
Rear calipers 5-10.
This x1000
Old Apr 17, 2016 | 01:21 AM
Cotozic's Avatar
Never knew people still had so many problems with their rear calipers.
Old Apr 17, 2016 | 01:54 AM
Bad *** Newb
I believe this is the part number 6582950A00. Good luck, they're $10 each from what I've found before
MAF or primary O2 sensor would be the most likely cause of poor fuel economy. When the mafs go bad they tend to read as if there's a lot more air and the ECU consequently dumps more fuel. You should see like 17 city in bad conditions, definitely not combined.
Savage
Old Apr 17, 2016 | 09:58 AM
fat_kid's Avatar
1. It's an automatic. - should have bought a manual
2. My brake rotors are warped and cause steering wheel vibration during high speed braking. - go get them fixed
3. My 5th gen is a California compliant car. - suck it Cali!
4. My hood latch is a little lose and I can see movement at highway speeds with a head wind. - adjust the rubber bumpers
5. The steering wheel is not perfectly aligned with the wheels. - get an alignment
6. The steering wheel is too large. - most women find this a plus
7. My car stereo will, on occasion, switch from fm to am for no apparent reason.- conduct a seance
8. I have only averaged 17mpg combined. - driver slower lead foot
9. The rubber gasket, for lack of a better term, around my gear selector has lifted up at one corner. - i have a manual so IDK
10. There is a small chip in my windshield directly in front of the drivers seat, visible only after detailing the windshield. - get that fixed at any auto parts store
Not mentioning-
11. Steering radius
12. Oil burning
Old Apr 17, 2016 | 10:08 AM
VQ35maxima=Beast's Avatar
This is for my 02
1. Oil burning
2. Turn radius compared to my 00
3. Still have pre cats
4. both fog lights are cracked
5. I don't have a OEM wing
6. my hood bumpers are non existent
7. Autotragic
8. Stock BOSE isn't loud enough
9. Solid rear axle
10. Did i mention i still have pre cats?
Old Apr 17, 2016 | 10:56 AM
george__'s Avatar
Gen 5.5 needs better brake pedals
It's tooo linear
Old Apr 17, 2016 | 12:21 PM
rbaksi's Avatar
Rear calipers are a pain.
RUST RUST RUST- Rear fenders and lower radiator mount
Otherwise pretty happy. If you're trying to make this a sports car you will be dissapointed.
Old Apr 17, 2016 | 07:22 PM
L_U_D_I_AMaxima's Avatar
I agree with the rear calipers pain... after rebuilding mine and only lasting about 15,000K I end up replacing those with the rebuild units from the parts store... well worth the lifetime warranty and not having to deal with repairing those ever again. Rust... sure I fixed the rear fenders about 4 years go and everything looked great now its back to where it started. Lower radiator support is not that big of deal... May be because I replaced it twice.. once on my 2000 and once my 20th? you are correct... the A33 will never be a sports car but the look on some sports car owners face after they have a really hard time keeping up with my quarter of a million mile 4 door grocery getter - priceless
Old Apr 17, 2016 | 07:26 PM
Bad *** Newb
No one tries to race me. A couple hondas have attempted ricer fly bys (just sad), but muscle cars ignore me. I think they're scared b/c they don't know what to make of the exhaust LOL
Old Apr 17, 2016 | 08:14 PM
george__'s Avatar
the vq35de with exhaust?
Old Apr 17, 2016 | 09:07 PM
TSelanne's Avatar
1. driver seat leather is ripped on side by switches so can see when door is open
2. up volume on steering wheel changes radio station
3. gas mileage rarely gets above 22
4. rust
5. rust
6. rust
7. rust
8. rust
9. rust
10. rust
that said I love my max
Old Apr 18, 2016 | 07:03 AM
Blassmasta's Avatar
It really is a love / hate situation with these friggin' cars.
1. Rust
2. Shifter is vague and feels cheap
3. Engine is a ticking time bomb (this covers disintegrating converters, bad piston rings and oil burning)
4. Turning circle
5. Rattle under dash that I CAN NOT FIND
6. Subwoofer rattles the interior
7.Creaking clutch pedal / clutch fork / TO bearing
8. Rear Calipers
9 Core support
10. Constantly chasing clunks, bangs and rattles in suspension
We can only post 10?
**** ... why is it we like these cars again?
Old Apr 18, 2016 | 01:57 PM
MadMax SE's Avatar
1. Rust
4. Turning circle
8. Rear Calipers
9 Core support
Compared to the competition in those same years these are a great bang for the buck and last a while. They can still be had for cheap aswell (got mine for 500). The same years Acura's where great, if you didn't have an automatic. Those things were literaly made of glass and fluids. God I hated mine.
Old Apr 18, 2016 | 02:08 PM
MadMax SE's Avatar
1. Torn interior
2. Lower Rust Support
3. Wheel bearings( I hate press style)
4. Bose speakers
5. Loose e-brake
All I can think of, I haven't driven the car much yet.
Old Apr 18, 2016 | 02:12 PM
Blassmasta's Avatar
I've heard about that. What is it that actually caused them to fail?
With the Maxima ... Big horsepower, GREAT looks and a six speed gearbox. Hell, lots of room too. I had a '99 - it was bulletproof. That's why the '03 pisses me off. I was hoping for the same but with more power and an extra gear. Which I got, minus the reliability.
Old Apr 18, 2016 | 02:23 PM
Bad *** Newb
Honda didn't think it was prudent to spray fluid on the gears or have a torque converter worth a crap. If you drove them hard they would just blow up quickly. Quite a few were on their 3rd tranny by 50k miles. Driven normally they might last to 100k lol
Old Apr 18, 2016 | 04:03 PM
AT978's Avatar
What is it that is wrong with the rear calipers on these cars?
Old Apr 18, 2016 | 04:29 PM
MadMax SE's Avatar
Child is right, there were people on there third tranny by 100k and even then they aren't safe. They re-used the case design from the 4speed they made previously AND added .2 liters to the motor expecting it to hold.....even the 4 speed autos had issues in their time. My Acura was poping into neutral while driving and shuddering under light throttle, it felt like I was going over rocks at 60. But on the bright side, they had great gas mileage (30+) and the motors lasted a long time.
Old Apr 18, 2016 | 04:33 PM
MadMax SE's Avatar
From what I read they love to stick closed sometimes, and I would feel as if the ebrake was left on.
Old Apr 19, 2016 | 07:41 AM
King_Ten_Ahead's Avatar
Those rear calipers like to freeze up making you spend an entire weekend trying to trouble shoot just for them to stop sticking on their own ))))
Old Apr 19, 2016 | 08:40 AM
NmexMAX's Avatar
dot dot dot ...
171k miles and only replaced 1 rear VC, 1 MAF, 1 coil pack, 1 Bose stereo.
This thing has been a gem.
Old Apr 19, 2016 | 02:48 PM
DFry97's Avatar
1. Rear quarter panel rust-brutal, getting body work soon
2. Radio-volume **** sometimes doesn't work, randomly swithces chanels and from fm to am or vice versa
3. Ride height-easy fix
4. FWD
5. Driver's seat has rips
6. Brakes-new ones going on soon
7. Odd suspension noises-come and go
8. Gas tank door and trunk will not open from the lever-trunk will only open by key and gas door needs one person pulling latch and another person applying pressure to gas door. Can't get gas alone which sucks!
9. Gas mileage could be better
10. Car is large but that doesn't really matter to me
Old Apr 19, 2016 | 02:50 PM
Bad *** Newb
I hate you and your moisture deprived place.
We had 61" last year and it didn't even rain for half of summer. I love storms and snow, but it's terrible for ****ty metal.
Old Apr 20, 2016 | 06:41 AM
NmexMAX's Avatar
dot dot dot ...
Lol this was Monday morning here:
https://maxima.org/forums/off-topic/...ml#post9106105
Average for here is 57.7" per winter.
Old Apr 20, 2016 | 11:12 AM
mclasser's Avatar
But does the DOT in New Mexico use salt on the roads?
Old Apr 20, 2016 | 11:21 AM
mclasser's Avatar
Just a garbage design overall. When my Accord's tranny went, the car shuddered violently shifting from 1st to 2nd. The shop let me watch when they tore it apart and the clutch packs were burnt to hell. Even with regular fluid changes, those things were destined to fail. It's funny because Honda made solid transmissions up until the mid-90s. They had firmer shifts which customers complained about so Honda redesigned them to shift more softly. That's when all the problems began.
Old Apr 20, 2016 | 12:06 PM
NmexMAX's Avatar
dot dot dot ...
Yes they do. My car looks like it escaped from a saltwater bath after it snows. Salt and cinder is what they use.
Old Apr 20, 2016 | 01:12 PM
Bad *** Newb
Are you a lot higher up than Santa Fe? They don't get much rain or snow, especially with the drought.
We don't get much snow, either (17" avg), but we sure as hell get a lot of rain. But these IDIOTS spray brine everywhere even when it's not going to snow. They do it just for fun to waste money, apparently (seriously, we didn't get a flake and/or air/ground temps were way above freezing and they just spray it on like a road bukkake). To top it off, they'll do it 3-4 days ahead (impossible to predict snow at that range here), so even if it snows, it just blows away and they bukkake it some more.
