Injector question
Old Jun 26, 2016 | 11:44 AM
Michael Stibbard's Avatar
Injector question
Just bought my baby back for the 5th time. Gonna build her this time. What are my options for bigger injectors? I have a 92 se, just wanna know what would be compatable with the VE motor. Any input is appreciated
Old Jun 26, 2016 | 05:16 PM
BenStoked's Avatar
Jesus was a Zombie.
Stock ecu, stock injectors. Piggyback, nistune, or standalone will get you bigger.
Stock injectors are side-feed, unless you get or make an aftermarket fuel rail.
Old Jun 27, 2016 | 10:20 PM
Maxpwer's Avatar
No turbo, no care!
Actually I've found an easy way to use cheaper and better top feed injectors vs expensive side feeds. A VQ35 injector rails lines up perfectly with our injector bosses. Weld two L shapped brackets to each side to match up with bolt holes in the intake manifold. Cost me $30 total and 6 top feed 550cc injectors can be had for $300.
Old Jun 28, 2016 | 05:50 AM
DanNY's Avatar
Ad·min·is·tra·tor
does it clear the stock intake manifold?
Old Jun 29, 2016 | 11:01 PM
Maxpwer's Avatar
No turbo, no care!
P
The latest ( last I checked) Bosch EV14 injectors come in 40mm, 48mm and 60mm. A stock injector is around 58mm and I'm fairly certain aleast the two smaller EV14s will fit with a stock intake manifold. A pathfinder manifold gives you a little more room.
Here is a link to Deatschwerks 40mm top feed 700cc injectors, $369 for 6.
http://www.deatschwerks.com/products...-0065-6-detail
You are only limited by knowledge.
Edit: Do you're own research on the quality of the EV14s, I've read they are top of the line a few years ago but opinions and experiences may have change since the last time I did research
Old Jun 30, 2016 | 06:15 AM
DanNY's Avatar
Ad·min·is·tra·tor
ahh man where were you when i was shopping for 550s? this is good to know...i'll keep that in mind if/when the side feeds i have goes.
Old Jul 5, 2016 | 08:14 AM
TonyJr's Avatar
94-96 q45 infinite fits there 370cc
Of course sr20det, 300zx tt also fits and there 370cc also..
MagikHype
20
Aug 26, 2016 07:36 AM
frank5079
Jun 24, 2016 11:58 AM
hacura3000
Jun 23, 2016 03:59 PM
collije
Jun 20, 2016 03:02 PM
BGTONIO1991
Jun 1, 2016 03:39 AM
