Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Heavy Duty Suspension
Old Jul 5, 2016 | 08:43 PM
Cephyr13's Avatar
I just bought a 2001 Maxima and I need to replace the rear struts and springs. I carry about 300 lbs in the trunk, so I need some good struts and springs. What's the cheapest quality struts and springs I can get that will hold some good weight? Race suspension is fine.
- Brian
Old Jul 8, 2016 | 09:02 AM
Prophecy99's Avatar
props for posting in the right section, but that isnt too much weight. you will be fine with any setup other than trash ebay no name parts.
i would say this, cheap and quality dont usually coincide.
Old Sep 22, 2016 | 06:33 AM
95maxrider's Avatar
Lightly modded
OEM parts should be good enough, but any aftermarket springs that have a higher spring rate to better support the weight are also going to be shorter than stock springs, which is not what you're looking for. The best thing you could do is get some coilovers (that come with stiffer than stock springs) and set the ride height exactly where you want it. But coilovers will hardly be the cheap compared with crap springs and shocks. Do you want it cheap, or do you want it right? Because you can't have both.
Old Nov 4, 2018 | 06:03 PM
irish44j's Avatar
retired moderator
Considering the stock suspension is built to hold a couple adults in the backseat, which would be about 300lbs or more, I wouldn't think that weight in the trunk would be a major issue for stock suspension, assuming you're not also carrying people in the backseat.
And yes, I'm just posting because I haven't posted here in many years, lol...
Hi Nick
auveeb
Aug 3, 2009 10:39 PM
NYC2K2MaXx
Jun 26, 2008 07:01 AM
jtreed2000
23
Sep 27, 2005 06:29 AM
Magikone69
Oct 23, 2003 11:30 AM
Punch84
Apr 15, 2003 08:33 PM
