MAF sensor question
Old Oct 30, 2016 | 04:02 PM
khakuda's Avatar
MAF sensor question
I just ordered the Delphi AF10210 Air Flow Sensor which according to the parts suppliers is a direct replacement for the 1994 Maxima sensor. It just dawned on me....Are these plug and play? I don't know enough or have any ability to flash the ECU and assumed they were a direct swap.
Old Oct 30, 2016 | 06:37 PM
akurtzer57's Avatar
Yes a replacement maf direct bolt on. If you have a code thrown you may have to do reset on the ecm just unhook the battery for few min.
Old Oct 31, 2016 | 06:18 AM
khakuda's Avatar
Great advice, thank you.
Old Oct 31, 2016 | 08:40 AM
ac max 92's Avatar
Yes. PNP. Just need to make sure its got the same number of pins as your existing one. You may not need to reset the ecu but if so probably best to leave the battery unhooked at night and just put the cables back on in the morning.
Old Nov 3, 2016 | 06:29 AM
khakuda's Avatar
To keep the record for those with the same issue, the part worked perfectly. I pulled the negative battery cable, then unplugged the MAF sensor. The connector has a locking wire which I pushed back with a thumb tack pin. Loosened the hose clamp on the engine side and the 4 bolts on the air intake side. Cleaned out the air filter housing, put the new part on which required some force to mount inside the rubber boot on the engine side. When pushing the MAF into the rubber boot, be careful to push only on the plastic mounting area and not damage the mesh filter. Once everything was aligned, I tightened it all down, put the battery cable back on and everything worked perfectly. No check engine, smooth operation. Actually, even smoother than I remember.
