I have an engine oil leak coming from somewhere in the torque converter
I'm sure it's engine oil as the tranny fluid has been flushed and is brand new, would be red, not brown.
I have an image of where it is coming from. I had to take off a small metal plate with 2 nuts to expose the hole I'm looking in to.
the oil is yellowish as it is fairly new oil. it leaks enough that it creates about a quarter size stain wherever i park it. is it anything to worry about? should I just leave it be and keep driving it?
Most likely to be the rear main seal, as I think I am looking straight up into where the engine meets the torque converter. Is it worth it to try something like blue devil sealer? It clams to "permanently" restore old seals, but I kind of doubt that is true...
The new CV axle stopped the trans fluid leak (finally) and that's when I realized I had ANOTHER leak that's not tranny fluid. Really banging my head right now lol.
I would not have the tools necessary to do the rms replacement myself, so I would have to take it to a mechanic...
The nwew CV axle stopped the trans fluid leak (finally) and that's when I realized I had ANOTHER leak that's not tranny fluid. Really banging my head right now lol.
You can used a bottle of. AT205 reseal. Check out Scotty Kilmer on YouTube how to stop a oil leak .. This stuff works and it will save you time and money .. You can pick it up on Amazon for about 10$ .. Just giving you a option
I have a Honda 3.5 L V6 with a chronic RMS leak problem. This is a known issue with that engine and some larger groups (e.g. Accord, Pilot, Odyssey) owners have been successful at getting Honda to resolve it. It costs about $1,200 to fix. Unfortunately for me, I have model without a large owner support base. So I'm stuck. Originally the RMS was replaced under the expensive extended warranty program at 60,000 miles. I was assured the replacement seal was the "new and improved" version. So 60,000 miles later the RMS started leaking again.
If I do replace it again, you can rest assured that I will be using a National seal and not Honda OEM. I'm done with Honda in more ways than one. That is one of the reasons that I'm here and not on some Honda forum.
The amount of oil leaking from that vehicle was embarrassing. If I went to visit someone I would often leave an oil slick in their driveway.
As as last ditch effort, I tried Valvoline High Mileage synthetic blend in the red bottle. It contains conditioners that are supposed to soften aging seals. Amazingly it slowed the leak to where it only uses 3/4 of a quart in roughly 5,000 miles. So it still leaks. But I've contained it to a level that I can live with until I sell the vehicle and look into purchasing a Nissan Titan to replace it.
I'm not an expert on oil additives and seal conditioners but I see Scotty Kilmer recommends a product named AT-205. I like the idea that is a liquid conditioner and not a thickener. I may try this to see if it will slow down the Honda leak.
Oil conditioners can only go so far. Sometimes you just can't reverse years of wear or a bad design. Once in a while you might have the conditions that allow a seal conditioner to work. It doesn't cost much to try if you think it won't do damage elsewhere.
I have had a 97 max and a 96 i30 and a 98 i30 all leaking from same spot. On all three it was the rear half moon gasket on oil pan. They crack from age and heat. Its a big job to replace but well worth it.
