AIR Bag reset procedure for 99 Maximas
Old Dec 3, 2016 | 07:16 PM
edwardh1's Avatar
I have a 1999, i30 about every 3 years it has a brain failure and the air bag light flashes, lucky so far I wiggle the under seat plugs and it has gone away after I do the reset procedure. this time I look on the net and there seem to be several different reset methods.
- mine for a 99 was a turn key on, push the door switch a number of times, with off key, close door then restart engine.
- one of the "new" methods (maybe for later 04, 06 etc models) describes a turn the ign switch off and on 5 times when the air bag light first goes off
- there might be another
What is the best reset method for our 4th generation cars? mine is a 1999. do we have a sticky.
it sounds like a big nissan problem from looking at the internet
thanks
Old Dec 3, 2016 | 08:05 PM
CS_AR's Avatar
There a thread on that topic below that I used on my 99 model. I've done it manually and with the help of NDS1.
https://maxima.org/forums/4th-genera...-question.html
Air Bag Reset Procedure
1) Open driver door
2) Turn ignition switch to the on position
3) Press the door switch button 5 times in 7 seconds.
4) Turn the ignition switch to the off position
5) Turn the ignition switch on and proceed with starting the vehicle.
Old Dec 3, 2016 | 08:21 PM
edwardh1's Avatar
after step 3 do you close the door, or not needed?
thanks
Old Dec 3, 2016 | 08:24 PM
CS_AR's Avatar
thanks
I don't recall closing it.
Old Dec 3, 2016 | 08:30 PM
CS_AR's Avatar
IIRC, sometimes it took a couple of reset cycles to enter and exit diagnostic mode. Then the light would stay off.
Old Dec 4, 2016 | 07:54 AM
edwardh1's Avatar
some say the cause is loose under seat air bag connectors, the yellow colored ones- has anyone disconnected them or just wiggle them to ensure the pins contact well?
