Car cranks faster with 34R battery.
Just got a 34R battery a few weeks ago after doing some research on the maxima.org and other places and found out that the 34R batter is stronger and better than 24F and 35 group batteries. The crank amps the 34R interstate are 800 cold cranking amps and 1000 cranking amps in warm weather. This is the strongest and most efficient battery for our cars and the most expensive as well as it costs 254.95 to 282.95 on interstates website. I got mine at costco for 83.99. If you have slow starting issues, this will definitely help. Every morning my car would crank slow but now no more. After 4 weeks it no longer cranks slow as it starts under a second.
24F, 34R are just size designations. Along with the bigger size, sometimes comes more CA and CCA.
You can get 24F batteries with 800 CCA...
I'm not really getting the point of this thread.
Maybe you had a weak battery before? So of course installing a brand new spanking battery is going to help. Even a brand new 500 CCA battery may have performed better than your old one, and you'd be saying the same thing.
How many CA and CCA did the OEM battery come with?
Maybe you had a weak battery before? So of course installing a brand new spanking battery is going to help. Even a brand new 500 CCA battery may have performed better than your old one, and you'd be saying the same thing. How many CA and CCA did the OEM battery come with?
Code:
Standard BCI Automotive Battery Sizes Standard battery size groups are established by the BCI. Battery Council International 330 N. Wabash Ave, suite 2000, Chicago IL 60611 312.644.6610 www.SourceBCI.com BCI GROUP NUMBERS AND DIMENSIONS PASSENGER CAR AND LIGHT COMMERCIAL BATTERIES 12-VOLT (6 CELLS) 1994 to 2013 Maximum Overall Dimensions (see footnote 2) BCI Group Inches Millimeters Number Length Width Height Length Width Height 21 8.1875 6.8125 8.75 208 173 222 24 10.25 6.8125 8.875 260 173 225 25 9.0625 6.875 8.875 230 175 225 26 8.1875 6.8125 7.75 208 173 197 27 12.0625 6.8125 8.875 306 173 225 33 13.3125 6.8125 9.375 338 173 238 34 10.25 6.8125 7.875 260 173 200 35 9.0625 6.875 8.875 230 175 225 41 11.1875 6.875 6.875 293 175 175 42 9.3125 6.8125 6.8125 243 173 173 43 13.125 6.875 8.0625 334 175 205 45 9.4375 5.5 8.9375 240 140 227 46 10.75 6.8125 9 273 173 229 47 9.6875 6.875 7.5 246 175 190 48 12.0625 6.875 7.5625 306 175 192 49 15 6.875 7.1875 381 175 192 50 13.5 5.0 10.0 343 127 254 51 9.375 5.0625 8.8125 238 129 223 52 7.3125 5.8125 8.25 186 147 210 53 13 4.6875 8.25 330 119 210 54 7.3125 6.0625 8.375 186 154 212 55 8.625 6.0625 8.375 218 154 212 56 10 6.0625 8.375 254 154 222 57 8.0625 7.1875 6.9375 205 183 177 58 10.0625 7.1875 6.9375 255 183 177 59 10.0625 7.625 7.75 255 193 196 60 13.0625 6.3125 8.875 332 160 225 61 7.5625 6.375 8.875 192 162 225 62 8.875 6.375 8.875 225 162 225 63 10.1875 6.375 8.875 258 162 225 64 11.6875 6.375 8.875 296 162 225 65 12.0625 7.5 7.5625 306 190 292 70 8.1875 7.0625 7.6875 208 179 196 71 8.1875 7.0625 8.5 208 179 216 72 9.0625 7.0625 8.25 230 179 210 73 9.0625 7.0625 8.5 230 179 216 74 10.25 7.25 8.75 260 184 222 75 9.0625 7.0625 7.6875 230 179 196 76 13.125 7.0625 8.5 334 179 216 78 10.25 7.0625 7.6875 260 179 196 85 9.0625 6.8125 8 230 173 203 86 9.0625 6.8125 8 230 173 203 90 9.6875 6.875 6.875 246 175 175 91 11 6.875 6.875 280 175 175 92 12.5 6.875 6.875 317 175 175 93 15 6.875 6.875 354 175 175 22F 9.5 6.875 8.3125 241 175 211 22HF 9.5 6.875 9 241 175 229 22NF 9.4375 5.5 8.9375 240 140 227 22R 9 6.875 8.3125 229 175 211 24F 10.75 6.8125 9 273 173 229 24H 10.25 6.8125 9.375 260 173 238 24R 10.25 6.8125 9 260 173 229 24T 10.25 6.8125 9.75 260 173 248 26R 8.1875 6.8125 7.75 208 173 197 27F 12.5 6.8125 8.9375 318 173 227 27H 11.75 6.8125 6.8125 298 173 235 29NF 13 5.5 8.9375 330 140 227 34R 10.25 6.8125 7.875 260 173 200 36R 10.375 7.25 8.125 263 183 206 40R 10.9375 6.875 6.875 277 175 175 51R 9.375 5.0625 8.8125 238 129 223 58R 10.0625 7.1875 6.9375 255 183 177 95R 15.5625 6.875 7.5 394 175 190 96R 9.5625 6.8125 6.875 242 173 175 97R 9.9375 6.875 7.5 252 175 190 98R 11.1875 6.875 7.5 283 175 190 Note 2: "The maximum height includes the terminal posts. Width and length measurements are generally to the widest point, including protruding flanges, except for hold-down flanges at the bottom of the battery. See the diagrams in the BCI battery Replacement Data Book for full details."
Back in the day, if you didn't have an Optima, you weren't cool (and it didn't fit without adapters). Today? Just go to Costco, pay the $83, and get an Interstate, it starts the da** car! And free hassleless replacement in 42 mos. 700 CCA @ 0F is more than good enough, 130 RC.
Gregg Stewart
May 11, 2017 08:31 AM
