1999 maxima antenna replacement
Old Dec 27, 2016 | 05:39 AM
dasboot64's Avatar
What is the best and cheapest way to replace a power antenna with a fixed antenna.
Old Dec 27, 2016 | 06:27 AM
M in KC's Avatar
Remove the powered antenna's motor/gear box assembly. The antenna cable will mate up with the new non-powered antenna you buy. Use a pair of needle-nosed pliers to remove the retaining nut on the outside of the fender or a small screw driver and gentle taps from a mallet careful not to mar your paint. A cheap fix antenna can be had for probably $20 USD. A replacement mast if your motor still works would be about $25 USD or so.
Old Dec 29, 2016 | 10:18 PM
maximaham's Avatar
i purchased a used power antenna from a member for about $20 just looks better to me plus i wanted my antenna down when not listening to the radio.
