Cracked fuel gauge sending unit
Old Dec 27, 2016 | 02:08 PM
marianm's Avatar
My Maxima is leaking fuel from the sending unit when tank is close to full, otherwise it's just fumes that are leaking.
There is a hairline crack on the driver side of the connector part of said sending unit.
I did find DennisMik's very useful post on how to replace it with a new one.
I'm just wondering whether a new part is actually just as old as the cracked one, minus the gas exposure.
For those that replaced it with a new one, how is it holding up?
For those that have tried to glue it, how did that work out?
Did anyone find some cheaper (than $130) alternative for a new one?
Old Dec 27, 2016 | 06:59 PM
Rit's Avatar
Rit
If you can get at the crack, there are some pretty good adhesives that are impermeable to gasoline. I would go that route 1st.
Old Dec 28, 2016 | 08:08 AM
You could try to plastic weld then epoxy over it. May work for a while depending on how well the job is done.
Old Dec 28, 2016 | 09:10 AM
DennisMik's Avatar
The units that you would buy today are not as old as the car. They could be 2 - 3 years old, but definitely not 15 or 20 years old.
I thought about trying to somehow fix/patch the crack by various methods including even melting the plastic. However I took a pessimistic view of patching and replaced the unit. If I were to try some kind of patching, I would remove the sending unit and do it from both sides of the crack.
Just my .02
Old Dec 28, 2016 | 09:57 AM
schmellyfart's Avatar
Mine had developed cracks which lead to similar symptoms about 4 years ago. I repaired mine by removing and sanding down the area on and around the crack and used JB Weld to seal it, haven't had it leak since then.
Old Jan 13, 2017 | 10:12 AM
marianm's Avatar
I ended up using JB-Weld WaterWeld on both sides of the sender. Once I removed the unit I saw that the cracks were more extensive than I could see from the outside; I should have bought a new unit. So far, after 6 days, no gas leaks to complain of, no gas smells.
I was surprised at how clean the gas tank was.
Unlike Dennismik, I had no rubber seal for the inner connector that goes to the fuel pump.
Even though I bought a new one for this job, I left the previous O-ring in there as it seemed fine.
Old Jan 13, 2017 | 06:40 PM
DennisMik's Avatar
Congrats on a successful patch. Hope you have the same success as schmellyfart (post 5) has had.
Using that old o-ring should be fine.
