Stalled, Barely Start/Ran with Gas Smell
Old May 2, 2017 | 07:58 PM
Violator's Avatar
Car randomly stalled while idling, started (barely) and was barely running down the street before stalling again and it wouldn't start back up. Smoke was pouring out the tailpipe and the pedal wasn't really doing anything it was like in and out and barely accelerating. Smelled like gas, and wouldn't start back up again after it stalled the second time.
I had the intake manifold off doing spacers, spark plugs (oem ngks), fuel filter (k&n), and injectors (Chinese). I managed to snap one of the inside studs on the lower intake manifold and thought I'd be alright considering I think I went overkill with the rtv. Well the car has been misfiring and it's actually cylinder 4 right by that stud, tried a new coil and it still misfired so I put the old one back.
was gonna go over to where the car is running tomorrow and try to get it running I wanna be as prepared as possible. For now I was planning on trying that other coil, then try an OEM for that injector, I guess then spark plug even though it's new OEM
Old May 2, 2017 | 09:32 PM
My money is on a bad injector(s). It's flooding badly. Even if an injector is new, don't trust it. Diagnose and inspect/test.
Old May 2, 2017 | 09:47 PM
DennisMik's Avatar
When you replaced the injectors, I hope you used new o-rings. Old o-rings can crack and leak.
Pull the spark plugs out and see which ones are black (or even wet) and this will tell you which cylinder.
Old May 3, 2017 | 08:02 AM
jholley's Avatar
^ +1
Did you apply motor oil to the O-rings? If not the lower ring can crimp and leak into the LIM while the upper can crimp and leak outside of the cap.
Old May 3, 2017 | 09:40 AM
JvG's Avatar
JvG
Originally Posted by jholley
^ +1
Agreed.
Makes sense. I oiled those o rings when I installed my injectors. No issues.
Old May 3, 2017 | 03:23 PM
PH98I30's Avatar
Gotta be the injectors.
Old May 4, 2017 | 04:30 AM
CS_AR's Avatar
^^^ +1 I've always lubricated injector o-rings before installation. No issues.
Old May 9, 2017 | 03:28 PM
Violator's Avatar
Car wreaks of gas and there's actually a pretty decent leak from the oil pan area, front 3 injectors seemed dry.
I thought I used a little lube on each one but I don't think I did on the lower o rings. Seems weird to me that I put them in weeks ago and i just got this issue
On the stock injectors a lot came out with broken pintles, tips for avoiding this?
Old May 9, 2017 | 05:12 PM
jholley's Avatar
Both upper and lower O-rings should be lubricated to get a safe and secure fit into the fuel rail
Since you didn't lubricate them a lower O-ring could of possibly crimped and is now leaking gas into a chamber.
For a quick check remove the spark plugs. A dark and/ or wet plug indicates a leakage.
Old May 10, 2017 | 06:10 AM
Violator's Avatar
Got the fuel rail off last night and the rear middle injectors lower o ring was half squeezed out and the pintle cap was gone.
I'm gonna hopefully get pintle caps and new o rings today if any of the auto stores have them, remove all 6 injectors and reseat them
Old May 10, 2017 | 06:44 AM
jholley's Avatar
Congrats on solving your issue!
If no local store has them in stock then try this set
http://www.ebay.com/itm/201023507424...%3AMEBIDX%3AIT
CS_AR and I have both used these CS Performance injector kits. They're a great fit and I got them delivered within 3 business days of ordering.
Old May 10, 2017 | 06:52 AM
jholley's Avatar
To get my injectors securely fit onto the fuel rail I removed the LIM
I installed new gaskets for the LIM and UIM with this Felpro kit MS91241
Here's a thread CS_AR is currently constructing to install and refurbish our injectors
https://maxima.org/forums/test-posts...ml#post9146107
