Good or Bad idea to get a junkyard A/C condensor?
A/C condenser might be shot as I watched all the refrigerant slowly seep out this afternoon. I can either buy it in store or online, but with some of the other issues I'm fixing, I'm having to go bare bones cheap on it which I've found...but it'll take a few days to arrive.
So thinking if I find something at the yard it'll be a good quick fix. But, living in a humid climate and it being summertime...I'm concerned of rust, bugs, and corrosion inside the condensor. Especially if the system is open. Not to mention unforeseen leaks. I know for sure...I stopped fooling with junkyard compressors. But a condensor seems somewhat easy to get to if it doesn't work out.
Lately I've been having good finds...but don't want to waste my time either.
I would say it is a toss up depending on if you have an air compressor to flush a junkyard one. But then you would have to buy flush so your price point would be about the same.
Just remember there is a change from 95-96 to 97-99. The difference is there is a change in hose end connector coming from the compressor.
I would not worry much about leaks as you can visually inspect and will pull a vacuum. I would be more worried about trash from a shot compressor.
The yard I go to the most does not drain the ac. So if I found a correct year with pressure and could flush I would go that route.
Thanks...yeah I tend to avoid 95-96 as their designs tend to be a bit different. I always have good luck with i30 parts. Better maintained of course, but not always.
The condensor I want to buy says you can't flush because it's a parallel design. I wonder if they are all like that
I found a condenser for like $56 brand new. However, only thing I still would have to take everything loose, and the drier and get it vacuumed and recharged. Which conveniently, I can't take the time or cash to do right now.
And it's so hot this week, riding in a car with no a/c I've not done since 2011. It's brutal I almost passed out while driving today. So, I have to take the even cheaper route and find a good r134 with leak sealer. I just don't want to mess up my compressor either.
Here's an interesting article about parallel condensers below.
https://globalpartsdistributors.word...pressor-fails/
That link doesn't work :-(
But if I could see and hear the leak, then that means the leak sealer won't do any good then? I was able to visible see the gas coming out. I really don't like to use such products considering how cheap it is with aftermarket parts...but Even if it's just something that lasts for a couple weeks until I can get to it.
