Mass airflow sensor gasket?
Old May 28, 2017 | 08:20 AM
discobiscuit's Avatar
Hello. I recently purchased a 95 Maxima. A few days after the purchase the check engine light came on so I hook up the OBD reader. THe code indicated the MAF sensor was bad so I'm in the process of replacing the sensor.
As I removed the old sensor I noticed there was what seemed to be a rubber gasket on the end of the sensor that does into the throttle body. I've done several searches but have been unable to find a replacement and was hoping someone would point me in the direction of where I can purchase a new one.
Thanks in advance for your help.
Old May 29, 2017 | 08:02 AM
FanaticMadMax's Avatar
I never seen a gasket for one but I have heard of it. You might wanna check see if the new MAF sensor comes with a rubber gasket. otherwise, try AutoZone, Advance or NAPA see if they carry the gasket itself.
Old Jun 5, 2017 | 12:43 PM
UTmaxima82's Avatar
There is a o-ring or seal (whichever you want to call it).
Or you could try the dealer you know. OEM Part # 22683-16V00 and its a whopping $2.40.
Old Jun 5, 2017 | 01:10 PM
Turbobink's Avatar
+ 1 ... no "gasket" but an o-ring.
See the green o-ring?
