NISformance Group Buy JWT High Performance Camshafts for 2009-2014 Maxima Engines
Old Jun 7, 2017 | 06:24 AM
SurraTT's Avatar
HR Swap Pioneer
NISformance Group Buy -- JWT High Performance Camshafts for 2009-2014 Maxima and 2007-2012 Altima 3.5
NISformance has been been working closely with JWT for years on these cams. We have tested the prototype set in our shop car with great success. Here we are with an initial release in a special group buy!
NISformance is the exclusive dealer of these cams -- you won't find them anywhere else. These are the ONLY cams available for these engines (FWD HR) (2009-2014 Maxima and 2007-2012 Altima 3.5)
JWT C2H cams are designed exclusively for the VQ35DE (2009-2014 Maxima and 2007-2012 Altima 3.5) engines. A 262.5 degree duration with an aggressive lift near 12mm requires this profile to be used with JWT valve spring set. These cams are designed for use in engines with stock pistons. By designing in more lift with a moderate duration, it makes this profile excellent for these HR high flowing head engines. ECU tuning is required after these cams are installed!
Pricing: $1500 regularly, special group buy price: $1350
Includes:
4 camshafts
Custom trigger wheels
4 cam gear bolts
We gained 30 HP and 22 FT-LBS TQ at 7000 RPM
Group buy open from June 7-June 30
Minimum 10 orders
Estimated Shipping date MID to LATE JULY 2017
To take full advantage of these cams, the rev limiter needs to be extended much higher than stock. In order to do this, you need upgraded rod bolts and an upgraded oil pump (and a non-leaking oil gallery gasket). We have these available also at special group buy pricing!
Applications:
2002-2014 Maxima
2002-2012 Altima
Must be using the FWD HR engine (09-14Maxima 07-12Altima)***
Installation and tuning is available at NISformance contact us for a quote.
FREE shipping to continental USA! Other please contact us for shipping quote!
PURCHASE THROUGH OUR WEBSITE CLICK HERE
Old Jun 14, 2017 | 12:14 PM
freezer's Avatar
I like the top end gains but can some of that low end grunt can be recovered via tuning or is that characteristic of the cams?
Also wondering whether variable exhaust valve timing tuning is necessary to take full advantage of these cams? Or is the exhaust cam designed to operate optimally in the neutral position? The test car has a Haltech so I am inclined to believe EVT timing was utilized. I intend to flash my stock ECU and perhaps pursue EVT tuning down the road.
Old Jun 15, 2017 | 02:56 PM
SurraTT's Avatar
HR Swap Pioneer
Performance cams move the power to higher rpm.
EVT is a benefit if its able to be adjusted forsure. It really depends on how much it cost to add that function sometimes its worth it sometimes it not.
Let us know if you have anymore questions.
Old Jun 22, 2017 | 10:04 AM
SurraTT's Avatar
HR Swap Pioneer
Bump list updated!
A reminder, to get in the group buy you must purchase the cams from our website. You can also get in on the group buy now, then install cams later on.
Old Jun 26, 2017 | 08:44 AM
SurraTT's Avatar
HR Swap Pioneer
FINAL WEEK!!! Group Buy CLOSES FRIDAY!
Accepting DEPOSITS $700 to get in this group buy! Then $650 once cams are ready to ship!
Old Jul 28, 2017 | 06:06 AM
SurraTT's Avatar
HR Swap Pioneer
update:
Group buy was a success!
We should have cams in next week!!!
Old Aug 31, 2017 | 03:38 PM
SurraTT's Avatar
HR Swap Pioneer
All cams have been shipped. We have installed some here already!
Thanks for all the support!
