Towing a Maxima
Old Jun 28, 2017 | 11:58 AM
bluefish7's Avatar
Towing a Maxima
Hello! Does anyone have experience with towing a Maxima (mine is 09) either with a tow dolly and the front two wheels up or flat towing with all four down? I want to pull behind an RV but looking to see if it is difficult or otherwise not the best car to do that with. Thanks
Old Jun 28, 2017 | 12:30 PM
Rich96's Avatar
I know very little about the subject, but have a friend who just went through this. It is my understanding that very few cars can be flat towed these days due to the transmission- in particular CVT.
I know he used an HRV due to the manual transmission, and eventually replaced it with a Grand Cherokee.
https://www.edmunds.com/car-buying/w...ind-an-rv.html
Old Jun 28, 2017 | 04:41 PM
Richard66's Avatar
Following two paragraphs are from the owners manual:
FLAT TOWING Towing your vehicle with all four wheels on the ground is sometimes called flat towing. This method is sometimes used when towing a vehicle behind a recreational vehicle, such as a motor home.
Continuously Variable Transmission. To tow a vehicle equipped with a continuously variable transmission, an appropriate vehicle dolly MUST be placed under the towed vehicle’s drive wheels. Always follow the dolly manufacturer’s recommendations when using their product.
Old Jun 30, 2017 | 02:17 PM
bluefish7's Avatar
Ok it sounds like a great description of what flat towing is, but does not say it should be avoided? Thanks for pulling that out
Old Jun 30, 2017 | 04:41 PM
Richard66's Avatar
This also from the same section of the owners manual. BTW where it says "Automatic", CVT's are included.
CAUTION
● Failure to follow these guidelines can result in severe transmission damage.
● Whenever flat towing your vehicle, always tow forward, never backward.
● DO NOT tow any automatic transmission vehicle with all four wheels on the ground (flat towing). Doing so WILL DAMAGE internal transmission parts due to lack of transmission lubrication.
● For emergency towing procedures refer to “Towing recommended by NISSAN” in the “In case of emergency” section of this manual.
Old Jul 1, 2017 | 07:08 AM
Maxgig's Avatar
The only way(s) you should tow a Maxima is either with the front wheels off the ground, on a dolly or on a flat bed trailer or tow truck with all the wheels off the ground. I personally have used the dolly method for 2 of my front wheel drive cars, (03 Maxima & 00 Saab) with no damage to the transmission.
Old Jul 10, 2017 | 11:36 AM
bluefish7's Avatar
Thanks, is it true that you cannot drive in reverse with those dollys?
