Crankshaft Position Sensor Issue
Old Jul 13, 2017 | 06:47 PM
TMRsuccess08's Avatar
Good day everyone! I have a 2004 Nissan Maxima SE 6 speed with the 3.5L. I just recently purchased the vehicle and was told it has a 2008 engine in there currently. Here's the rundown; when I go to start the vehicle, it cranks but DOES NOT start 🤔. Once I release the key back to the ON position, I wait 5 seconds and try to start it again. This time the engine starts after about 4 seconds of cranking. Also, the crankshaft sensor pigtail connector is not plugged in at the time I start it. When I plug the connector in, it doesn't start whatsoever. My question is, couldnit be in the wiring itself? I canned the codes and it gave me the P0335 for the crankshaft position sensor circuit A, in which I replaced the sensor with a duralast part And still the problem persisted. What could it be? And thank you all in advance!
Old Jul 13, 2017 | 07:47 PM
smittybizzle's Avatar
Not sure, could be a wiring issue, worst case you need a harness but hopefully it's not that.
Old Jul 13, 2017 | 07:52 PM
Thanks for the reply! And I too hope that it's not a wiring issue. I can wire my own if need be but I'm currently looking online at specs for ohm readings on the sensor and voltage readings at the connector. But of course, nothing has caught my eye.
Old Jul 14, 2017 | 06:27 AM
Tarzan's Avatar
I have a new Delphi CPS in the glove box just in case. If I remember to do so, I can measure resistance over the weekend.
Old Jul 14, 2017 | 07:42 PM
Thank you Tarzan !! I would greatly appreciate it!
Old Jul 15, 2017 | 01:50 PM
DennisMik's Avatar
The Nissan FSM has the resistance checking procedure in it
Section EC page 280.
Link - http://boredmder.com/FSMs/Nissan/Maxima/2004/EC.pdf
Old Jul 16, 2017 | 09:44 AM
Ok thank you DennisMik I appreciate all of you for the help! I will check this today since it's my first day off in a while. Thanks again for everything!
Old Jul 16, 2017 | 04:15 PM
So I read the specs DennisMik posted and it says on my wiring connector it has three terminals.. looking at the connector it goes from left to right 1,2,3. Number one is supposed to have battery voltage when the key is switched on. But it does not. number 3 on the other hand has 12.71 volts while the key is on. So would an option be to cut number 1 and number 3 wires and swap them? Or would this cause more problems and fry the ECU possibly?
Old Jul 16, 2017 | 09:01 PM
DennisMik's Avatar
No - DO NOT cut and splice wires. If you go to page 278 and read step (or line) 3, there is a difference in which pin will have 12 volts on it based on which one of 3 transmissions is in the car:
quote - 3. Check voltage between CKP sensor (POS) terminal 3 (with 5 A/T) or terminal 1 (except 5 A/T) and ground with CONSULT-II or tester. - end quote.
Manual trans or 4 speed auto will have 12 volts on pin 1.
5 speed auto will have 12 volts on pin 3.
What I think is that by finding 12 volts at the connector, you have verified that the wires are OK. Another thing is that maybe you are looking at the connector backwards. If you look at the bottom of page 276, the crankshaft sensor connector (# F11) is drawn with a single line. This means that you have the connector unplugged and are looking at the end of it. If you have left the connector plugged in, then the pin numbers as you read them left to right are 1 2 3.
reference: section GI page 12, half way down, right side.
http://boredmder.com/FSMs/Nissan/Maxima/2004/GI.pdf
Old Jul 17, 2017 | 07:40 AM
Ok thank you! And I thought the PIN numbers were by me disconnecting the connector and looking at it that way. But just as you said, I have 12.7 V at the connector but it still has a delay. I will check the camshaft position sensors next alon with the voltage at the starter. I will do the tests tonight after work and let you all know what I find! Thanks again
Old Jul 19, 2017 | 11:10 AM
Costee's Avatar
It seems the sensor has to be warm to be able to determine its integrity off vehicle. The FSM states to check "Resistance Ω [at 25°C (77°F).]" Am I missing something? I'd be glad to see what you come up with.
Old Jul 19, 2017 | 11:15 AM
Tarzan's Avatar
No, that does not mean it needs to be warm - it only indicates at what temperature the nominal resistance has been measured. It changes with temp, so at 70 degree it will be slightly less, and at 90 it will be slightly more. The above note gives you a baseline.
Old Jul 19, 2017 | 11:33 AM
Costee's Avatar
Ok. Did you get to measure the one with you?
Old Jul 19, 2017 | 05:13 PM
Ok the one on my vehicle I measured about a week ago, and it's resistance if I can remember correctly was between 0.457-0.473 ohms. I'm starting to think it's the camshaft positions sensors. I'm going to suck it up and buy them tomorrow and install and let you all know if it works or not. I currently don't have access to an O-scope to get the readings. Thank you all for the replies!
Old Jul 20, 2017 | 06:40 AM
Tarzan's Avatar
0.4 Ohm sounds like almost a short circuit, I would expect something on the magnitued of 10x that.
No, I did not get to measure my CPS as parents took the car for the weekend and I only see it on the weekends. Will try to swing by in the next few days, again, if senility does not kick in.
Old Jul 20, 2017 | 10:05 PM
Ok that's perfectly fine Tarzan thanks for everything! And it's no rush, I am able to start it everyday and make it to school and work so I'm grateful! And I'll try and read the specs on the camshaft sensors as well and collect the data on them. Thanks again to you all for your help.
Old Jul 31, 2017 | 04:30 PM
Tarzan's Avatar
For the record, if you place the CPS with the mounting hole to the left and the sensor body facing upwards, then resistivity between the pins is as follows (1 is left, 3 is right):
1-2 1.1 KOhm
1-3 1.8 MOhm
2-3 1.8 MOhm
3-2 3.8 MOhm
3-1 3.8 MOhm
2-1 1.1 KOhm
The first pin is always positive lead of the Ohm meter. Sounds like there is a diode or a transistor inside.
Old Jul 31, 2017 | 07:30 PM
Thank you very much! I greatly appreciate it! But last question and then I will type the data specs I have tested... is the second reading supposed to be 1-3? I just want to make sure I get this right.
Old Jul 31, 2017 | 10:04 PM
So did you fix the issue?
Old Aug 1, 2017 | 07:06 AM
Tarzan's Avatar
You are correct, this was a typo, fixed now.
Old Aug 3, 2017 | 09:30 PM
Thank you all for the help! It was indeed the camshaft position sensor at the front of the engine. I appreciate all the help! Now to buy new injectors ��. It's like a never ending story haha. Thanks again for all your help!
