2006 Nissan Maxima
2006 Nissan Maxima
Suggestions please !!!!!
I was going down the interstate and my car began to sputter very bad and loosing power i was pressing gas petal and it seem as if car wasnt getting any gas to the engine , it began to jerk like it was trying car kept rolling and not going over 60 finally car would not do anything and just completly stopped
car will not crank now , when it turns over will not catch
ive replaced all sensors expect maf car is throwing a exhaust code
Code is PO470 if I'm not mistaken & fuel pump was my next Get to , I've replace Crank Shaft Sensors The Sensor That Goes Under the car that has to do with the oil About 200 dollar worth of sensors
I'm afraid I can't find any code for P0470 on any 6th gen Maxima. There is only one crank sensor. There are two camshaft sensors, which are no less important.
Camshaft sensors would cause a stall, but you can still re-start, they only push the car into limp mode afterwards.
Crankshaft sensor would cause a stall and no start.
Did you say it did not crank? Or did it cranked, but not start? Those are two completely different conditions.
I replaced the camshaft and crank shaft sensors , the car will no longer start now
