Timing Diagram Wrong, Vq35hr?
Old Aug 9, 2017 | 02:23 PM
Bradley Mersereau's Avatar
I need help. I'm diving into my timing system for the 2010 Max S. When I go directly to Nissans website or anyone else's for that matter, it shows a diagram of the timing cover (cool). The diagram for a 2010 Max shows two camshaft intake solenoids, attached the main cover, one on each side. The problem is mine also has what appears to be two exhaust solenoids protruding from the same cover. Here's the kicker, the only car I could find that on is a 350Z or anything else with a RWD VQ35HR!?
Old Aug 9, 2017 | 02:56 PM
blackmax14's Avatar
why are you getting it to timing? It is a non serviceable chain
Old Aug 9, 2017 | 04:11 PM
Non serviceable? What do you mean. I'm going to take the cover off and replace it. It's making a bad rattling noise. I believe it's the guides/tensioners but I'll just replace the chain too.
Old Aug 9, 2017 | 06:27 PM
blackmax14's Avatar
there is No service on the chain read the owners manual or call nissan it should not ever need it i have not heard 1 person with a 3.5 vq needing it!
Old Aug 10, 2017 | 09:17 AM
freezer's Avatar
No, the diagram isn't wrong. All 2009+ Maxima's have variable can timing on the intake and exhaust. https://parts.nissanusa.com/nissanpa...3441&siteid=14
If you're going to do the tensioner, do yourself a huge favor and replace the oil gallery gaskets. http://www.nisformance.com/EPS-Tunin...rykitfwdhr.htm
https://parts.nissanusa.com/nissanpa...partcode=13070
I wouldn't bother with the guides or the chains.
Don't forget to get all the necessary gaskets and seals.
https://parts.nissanusa.com/nissanpa...er1=237979N00A
https://parts.nissanusa.com/nissanpa...rtcode=23797XA
https://parts.nissanusa.com/nissanpa...partcode=13042
2x https://parts.nissanusa.com/nissanpa...rtcode=13035HB
6x https://parts.nissanusa.com/nissanpa...artcode=13042N
Old Aug 11, 2017 | 12:41 PM
maxud's Avatar
I believe you meant to say, it is not a maintenance item.
Timing chains don't require same maintenance as timing belts, aka regular interval replacement.
That is not the same as not serviceable. Timing chains are not perfect and do wear out/stretch, as well as guides wear out/fail, or tensioners.
The difference is that its a much harder to service item.
OP, good luck getting it done, are you pulling the engine or going to do it in place? Besides limited access, the next hardest thing gotta be resealing the timing chain covers without inducing leaks.
Old Aug 11, 2017 | 06:18 PM
blackmax14's Avatar
well may be so but never seen a chain need to be replaced or a tensioner unless the engine was worn or being permanence built!
