Looking to Buy 92' Maxima, Stalls when Warm
Looking at a 1992 Automatic Maxima with a SOCH engine. It runs good until it's warm and then it stalls. Apparently it could be the distributor. Anyone here have any experience with a similar problem? What was the solution?
Check the Power Transistor- it's also known as ICM Ignition control module (at Autozone) It's next to the distributor. Mine was causing a misfire and cutting out when it heated up, so I replaced the coil, wires, Power Trans and also removed the dist cap and cleaned off the cranks sensor disc.
Defective corroded injectors connectors , TPS, IAVC corroded!
