subframe connectors vs. fstb & rsb on 95 with h&r's and kyb's
just wondering if anyone has a lowered max with the warpspeed frame connectors that had/has a fstb and rsb. as of now, my 95 has h&r's with kyb's, fstb and rsb. its starting to get annoying the way the car takes the bumps and it has developed rattles. what im thinking of doing now, is getting the sfc(both stages), and taking the other control bars off. im wondering if i can make the car handle better by stiffening the frame as opposed to the suspension , in turn, eliminating some rattles and making the ride better by not being as harsh. id like to know if anyone has any experince or has tried this themselves yet. if possible,i wantthe car to be able to still handle turns similar to how it does now, but improve driver and passanger comfort along with cabin noise. will swapping my fstb and rsb for warpspeed's sfc do this?
i know this is gonna be redundant but im trying to make my question as clear as humanly possible here so im not misunderstood.
basically make the car handle better(compared to just the h&r's) by stiffening the frame, and at the same time, make the car ride better by allowing more movement back to the suspension. will this improve driver comfort yet retain handeling? will the car handle the same or not? what are the pros and cons of doing this? is this just a waste of time and money cause it'll be the same? if so why?
softer on the bumbs but stiff in the turns.
thoughts?? opinions?? thanks in advance..
I thought the FSTB, RSTB, and RSB all help stiffen the frame, not the suspension. Adding a SFC would only make the frame that much stiffer, wouldn't it? I know what you're asking, but I'd leave my bars on the car, even with a new SFC. What do you think?
I have most of what your asking about, except for the RSB. I think you will like the subframe connectors on the car. Durring normal driving conditions you will not know theyer there. Take a sharp trun at 50 and you'll be thankfull you had em put on. With my car there is still some body roll but not much so I still have intentions to get a RSB too. Hope this helps.
John.
John.
Originally posted by KCTYPHOON
max'n out do you have the frame connectors? just wondering if thats your experience or just your opinion..
thezcarguy how does your car take the pot holes and bumbs?? any difference?
hmm.. intresting, but i guess its possible that his set is a different design than warpspeed's, or mabye his are bolt on rather than welded, or mabye has a broken weld somewhere?? mabye that would explain the noise. i think theres too many variables in this comparison for me to base my decesion on just from that. i do appreciate the feedback though.. thank you
I'm sure most people don't notice it.
Originally posted by max'n out
Yeah I woun't base your decision on that. It's a vary different car. I don't theres a bad weld. Don't know the specs on his setup very well. My guess though is that no matter what you will have some(not much) noise but i woun't sweat it. really the only reason I heard his is cuz im **** like that
Reduce Cabin Noise = Turn Up Stereo
ha, jk, I intend to get some SFC's, but working on the rest of exhaust right now. I have a pretty simple solution to finding out if cabin noise is reduced, prob just install the SFC with no other bars (are you keeping the springs and shocks on?) Then add the other bars and see if they make a difference. Post how things turn out. Always interested to see people's reaction to new products.
no matter what i do the springs and shocks are staying on. i was intrested to hear weather other peoples experience with the sfc first beacause i dont wanna spend a few hundred "just to see". know what i mean? if a few people can tell me im right or wrong then ill go from there. if not, then im gonna wind up at least taking off my rsb cause i cont put up with the noise in the car much longer. its embarassing to me to have a nice car looking car and have someone get it to get bounced around and listen to it rattle. the handeling has become less of an issue over noise and comfort these days.
No I don't have them. But I have driven a Integra with some soft of frame conecters. Handle great but when cold and you turn fast the just make this kinda little noise. Like cold metel stressing, and of course thats whats happning. But it did turn nice. It's not bad but is noticleable.
how you can you form an opinion on WSP subframe connectors when you dont own or have never experienced them?
Originally posted by Smooth Operator
show me pics of that integra's "soft of frame conecters". since you driven it i'm sure you have access to it.
Don't own the teg no. But I did have it in my possion for a few days while i worked on it for him. So I do have experiecne with them since they whre on his hoopty.
so, how can you form an opinion on the effectiveness of the warpspeed subframe connectors when you dont own or have never experienced them?
I'm not saying anything directly about hte ones on a max. If you read I said it's on a diff car don't base everything on that. It's an experience with a sfc. You think there all very different? I don't, not on a fwd car. Pretty much do the same thing. And so I gave info on that.
"Handle better yes. Softer and more quiet, No."
how descriptive. later we find out your reply was not based on experiences with a maxima, but an integra. there are several ACTUAL WSP SFC owners and people who have experienced with them that are more qualified than you are to opinionate on its effectiveness. a specific brand/manufacturer was queried and you replied with a definitive answer which was very misleading. whats the point of replying to something you know nothing of?
and yes there is a difference in SFCs. some companies use boxed members and some use cylindrical or oval tubes and types of attachments to the unibody. who knows if you even know what SFC are?
just curious if you confused some aftermarket lower control arm tie-bars that are available for civics/integras as subframe connectors? since they technically are bolted to and only to the integra's subframes, it may be referred to as "subframe connectors".
Originally posted by Jeff92se
removing the bars won't do anything. 90% of the harshness comes from the shocks/springs/wheels/tires. so if you want a softer ride, the shocks/springs gotta go
Okay.
well, id have to disagree with you there.. me and my friend basically have the same set up. i have a 95, he has a 96. we both have h&r's w/ kyb's and 18's. only difference really between the rims are mine are 8.5" and i belive his are 7". he has nitto's, i have toyo's, both a good quality and soft tire. our ride is NOTICABLELY different. takes the bumps like nite and day.. rite now i have my aftermarket 16's on cause i busted a rim on the nj turnpike and his car still rides way better than mine.. im not talking so much about driving on a smooth perfectly paved road. out here that doesnt exist. im talking more about how the car takes the bumps.
you should learn to read. the guy was asking about WSP sfc on maximas and its effectiveness. your first reply?
As someone who actually has the WSP SFCs on my car (both stages) I can tell you that it does firm up the ride a bit. The car feels much, much more solid, the back end follows the front like it should. You'll feel the difference over every set of railroad tracks you cross and every corner you take at speed.
I would recommend you try out stage 1 on your car for the longitudinal stiffness it provides and perhaps upgrade to stage 2 for a bit more lateral stiffness if you think you want it. I would also recommend you leave on your FSTB and your RSB. The FSTB provides a lot of lateral stiffness higher up and the RSB reduces body roll, things that the SFCs aren't designed to do and shouldn't do.
John.
Originally posted by thezcarguy
I agree with everything said in this post. I can also say that there is no loticable increse in cabin noise as a result of the SFC's. As far as going over the potholes and stuff the are is much stiffer and dose not squeek or rattle as much. Give em a try.
maxima-junky
Oct 7, 2015 06:13 PM
AaronL
Sep 23, 2015 03:34 PM
dvcamp
Sep 18, 2015 10:17 AM
