Will a '00 -'02 rear cross member sub frame control arm bracket fit a 4th gen?
Old Apr 16, 2018 | 09:31 PM
Maximeltman's Avatar
Any Ideas here? Mine is realy rusty and thinking of options.
Old Apr 19, 2018 | 09:15 AM
RA030726's Avatar
I'm nutty for Nissans
Are you talking about the triangular 3 bolt peice?
Old Apr 19, 2018 | 02:06 PM
maximaxi's Avatar
If the control arm is so rusty that you're considering replacing it for that reason alone, you know it will be impossible to remove it, so spray some oil on it now
Old Apr 25, 2018 | 06:50 PM
Yea the rear beam trailing arm... will it fit?
right! that and a map gas torch..
will it fit?
Old Apr 25, 2018 | 07:21 PM
RA030726's Avatar
I'm sorry, now I'm more confused. Is the part in question in this diagram?
Old May 2, 2018 | 04:09 AM
Yes #10...
Looks like it would fit but will it?
Old May 3, 2018 | 03:02 AM
krismax's Avatar
Father of the 00 VI
Here are the two diagrams with numbers .first is 96 maxima, second 2001-2004 Maxima I35.
It will not work,similar lookup code ,but part numbers are different.
Attached Thumbnails Will a '00 -'02 rear cross member sub frame control arm bracket fit a 4th gen?-431_a001.png   Will a '00 -'02 rear cross member sub frame control arm bracket fit a 4th gen?-431_a001-1-.png
Old May 3, 2018 | 08:14 PM
RA030726's Avatar
They are different. In 2000 the lateral linkage was moved to behind the beam. You can't replace the arms either. It's all one unit.
Old May 4, 2018 | 03:09 PM
BOOOO!!! Well darn. Thanks guys!
03maxima1
Aug 9, 2017 04:04 AM
Spence
Feb 26, 2013 09:39 AM
gen4maxima536
Jul 11, 2012 07:57 PM
grey goose
Sep 22, 2004 12:35 PM
