PCV valve
Old Jul 25, 2018 | 02:20 PM
Tamburitzan's Avatar
PCV valve
I keep getting a mass airflow sensor fault. I just discovered that a non functioning PCV can cause this fault. Where on earth is the PCV valve on a 2005 maxima with manual transmission???
Old Jul 25, 2018 | 08:08 PM
follyburr's Avatar
If it's like the 5speed, which i don't see why it shouldnt be, it is located behind the intake manifold. Right next to the 2 green plugs. Removing the windshield wiper cowl should give you more room to access the pcv valve.
Old Jul 25, 2018 | 10:30 PM
Thank you
You gave an accurate description. Does it unscrew or just pull out?
Old Jul 25, 2018 | 10:38 PM
follyburr's Avatar
unscrew. 22 or 24mm(I cant remember which one) socket or an adjustable wrench (crescent) will help.
Old Jul 25, 2018 | 11:22 PM
Thank you so much
i have the factory manuals. Believe it or not they show it, but do not tell how to remove it
zboy
Jul 30, 2004 07:01 PM
tyshah
Nov 25, 2002 09:23 AM
maxdout92se
Apr 10, 2002 03:00 PM
AzynRomeo
Aug 26, 2001 05:18 PM
petemo95se
Nov 29, 2000 10:38 AM
