Battery and Brake light...plse help...
Old Feb 3, 2002 | 11:15 AM
NmexMAX's Avatar
dot dot dot ...
Last nite on my way home, my battery light and brake light came on. The last time this happened my drive belts had came off, but this morning I checked the belts and they were fine, my brake fliud is full, any one know what could be the culprit? Bad alternator? What about the brake light?
Old Feb 3, 2002 | 01:23 PM
Sonic's Avatar
Either your battery or alternator is about to go. Get both of them tested.
Old Feb 3, 2002 | 01:39 PM
NmexMAX's Avatar
dot dot dot ...
Will do, I think it's the alt, cuz I changed the battery not too long ago.
Also when I was @ low rpms, the headligths would dim slightly.
Old Feb 3, 2002 | 01:42 PM
NickStam's Avatar
check the alty ASAP, or you'll be stranded.
Old Feb 3, 2002 | 08:42 PM
jmax
Could also be the regulator or a bad connection. But the most likely culprit is the alt.
Old Feb 3, 2002 | 10:14 PM
1MAX2NV's Avatar
I believe the voltage regualator is bulid into the alternator on the 4th.
Old Feb 3, 2002 | 10:20 PM
NmexMAX's Avatar
dot dot dot ...
Yup, on the 4th it is built in, bout a 3 hour job, looks like I'll b havin some fun soon.......
thnx guys
Old Feb 4, 2002 | 08:01 AM
jmax
Yes, it is built in. But I beieve you can replace the regulator with out hte expense of a new alt. But, if the regulator is gone, you won't be able to test the alt. And you should be able to pull the alt and install replacement in under two hours. Maybe not much less, but a little.
bigfrank
Oct 1, 2015 12:51 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
