Hub bearing and hub question
I have a 91 Maxima 5 speed. I'm having trouble finding new hubs anywhere as they are discontinued. But when I looked at the bearings themselves. It's the same part number from 89- 99???. So my question is if the bearing is the same part number would the 95-99 hub fit? . I couldn't find diameter specifications for the hub. But if it's the same bearing? Does it supercede the discontinued part?
I once had a 91 se 5 m/t maxima
before I sold it I noticed the cheap parts store Passenger cv axle's carrier bearing was making a rub,rub,rub noise
consistant with wheel speed
I knew that was it when I spray lubed the carrier bearing and the noise stopped a few times
Did you lift the front and check for play?
Yea I actually replaced the hub bearing last year saw it had play and slapped it back on. But what I did do was fill the gap with feeler gauges and put 4 spot welds to hold it in place lol. Feels great. I tried getting them from a junkyard but the closest one wants 200 to ship it to Chicago. There is one junkyard within 100 miles and I have a couple things off that one already.. I also found a place that will add material to the old hub and cut it to size. I am going to do it with the junkyard spindle that I'm ordering this weekend.
find a machine shop
bring your hub and bearing to them.
ask them what they can do to solve the problem.
they will probably machine down the messed up hub and press a sleeve over it.
why wouldn't a 4th gen hub work in this case?
That's what I just said they were going to do when I get the junkyard ones. They are going to press them for me too. And the inner spline is a different size ....too big.
is the inner race the same. you can always frankenstein the CV axle by swapping the outer piece with a 4th gen axle.
Maximeltman
Dec 20, 2008 11:13 AM
