2003 Cowl Seal replacement
Old Dec 29, 2019 | 04:47 PM
danega's Avatar
I've looked everywhere but can't seem to find a replacement part for the cowl seal. Apparently they don't make them anymore. Engine smell has been coming in and I'm really tired of turning on the recirculating switch. Can anyone recommend a replacement?
Old Dec 29, 2019 | 05:45 PM
slvr2KSE5's Avatar
There's nothing to seal. When it's not on recirc air will be coming in thru the cowl.
I would recommend repairing whatever is causing the smells.
Old Dec 29, 2019 | 09:12 PM
danega's Avatar
This is the rubber seal that goes between the cowl and the hood when shut. It keeps the engine fumes from coming through the vents below the window. The rubber is smashed down on my car and needs to be replaced. The part has been discontinued. Don't know if there is a part from another year that will fit. So far I can't find any and I'm wondering if I need to make my own from something I buy at Autozone.
Here's a link that shows what I'm looking for:
https://www.realnissanparts.com/oem-...MtNWwtdjYtZ2Fz
Old Dec 30, 2019 | 07:09 AM
Child_uv_KoRn's Avatar
Bad *** Newb
What I read: My valve covers are leaking, but I'm not going to fix it. There shouldn't be any fumes unless you delete PCV.
And wouldn't the air be sucked up from underneath instead of blowing down into the cowl? I think you must be burning a lot of oil on the exhaust.
Old Dec 30, 2019 | 11:45 AM
danega's Avatar
I'm not getting exhaust in the car. The engine makes fumes while it's running. Without the cowl seal the fumes come up between the cowl and the hood and are sucked into the vents under the windshield. It only smells when the car is stopped an the engine is running. Like at a red light. The valve covers are not leaking. Nothing else is leaking.
The problem is I can't find a replacement part. The piece of rubber that seals the hood and the cowl.
So the question is does anyone know where I can find the correct part? Is there another part that can be used from a different year or model. I don't think I'm the only one that could be having this problem. It's an issue on all cars. Just that other cars have the replacement parts available.
Here's an explanation of what I'm looking for: https://www.steelerubber.com/hood-to-cowl
Old Dec 30, 2019 | 12:37 PM
slvr2KSE5's Avatar
We understand what you're looking for. Bottom line is if it's discontinued you're gonna have to get creative.
Neither of mine have any smells from the engine bay or exhaust. They're also not leaking anything.
Old Dec 30, 2019 | 12:47 PM
danega's Avatar
Thanks Steve. I think I'll just get a standard seal at Autozone and cut holes to attach clips in the proper location and hope for the best.
Old Dec 30, 2019 | 11:42 PM
Bad *** Newb
You completely contradicted yourself. There are no fumes unless you have a leak.
Put some weatherstripping on top of the seal.
Old Dec 31, 2019 | 05:36 AM
Theslaking's Avatar
06 looks like it has a similar seal. Only 15 bucks. Worth a shot.
Old Dec 31, 2019 | 01:19 PM
danega's Avatar
Why the attitude? Engines smell when running. That's why they put the cowl seal there in the first place. If they didn't smell then there would be no need for a seal. Open your hood with the car running and stick your face in there and tell me you don't smell something.
Thanks for the weatherstripping suggestion but I think I'll use a seal from another car and make that work.
Old Dec 31, 2019 | 01:20 PM
danega's Avatar
Worth a try. Thanks for the suggestion.
Old Dec 31, 2019 | 01:32 PM
Bad *** Newb
No, they do not. JFC, think about what you're saying. An engine is sealed except for intake and exhaust.
Everything volatile in paint, plastic and rubber will evaporate off after enough run time. These cars are far from new.
The only thing exposed at all is auto tranny breather, PS fluid, and coolant overflow, but of course that's not evaporating at any rate detectable.
I can open the hood of any running car without a leak and smell...nothing.
Old Dec 31, 2019 | 02:31 PM
User1's Avatar
If you're stinkin, you're leakin.
James92SE
18
Apr 20, 2009 07:13 AM
lanky2882
Feb 14, 2005 07:09 AM
MAKSYMALNY
72
Aug 21, 2003 03:45 PM
fnkmaster
May 29, 2001 08:36 AM
