OEM lug nuts keep going bad
Old Jan 26, 2020 | 09:43 AM
MaximusN8's Avatar
Hi all,
So my wife's 2012 Nissan Maxima is on it's second set of OEM cone style lug nuts, the first set had to be replaced because they went from a 21mm and swelled up to a 22mm, it's been a year later and it has happened again the lug size is now a 22mm. I paid $130 from the dealer for the first replacement only for the same problem to happen again. Has anyone else had issues with cone style OEM lugs swelling and are there any aftermarket options anyone can please recommend?
Thank you
Old Jan 26, 2020 | 12:56 PM
TMartinLVNV's Avatar
The OEM lug nuts have a metal covering that gets distorted when you take them on/off enough times. I could not imagine paying $130 for a set of lug nuts. Get yourself a set of solid (one piece) chrome acorn style lug nuts. No covering to get distorted and fall off.
Gorilla and McGard are both fine products. About $1 for each lug nut.
M12 x 1.25. Hex Size: 19 or 21 mm
Old Jan 26, 2020 | 03:38 PM
LtLeary's Avatar
I ordered these back in 2014 and they are still going strong. McGard 65554CN Chrome SplineDrive Wheel Installation Kit (M12 x 1.25 Thread Size) - for 5 Lug Wheels
Granted they are around $100+ but 6 years later, still good.
Old Jan 26, 2020 | 04:31 PM
MaximusN8's Avatar
Yes I've heard about this metal covering on the OEM lug nuts, My 2010 Maxima has different OEM lugs than my wife's 2012. I would like to get her the same ones as mine but the difference is what concerns me..
Old Jan 26, 2020 | 04:34 PM
MaximusN8's Avatar
This is the ones I need for the 2012 Nissan Maxima
Old Jan 26, 2020 | 05:14 PM
LtLeary's Avatar
This McGards will fit fine. But, to each his own. I know that style means means more than function to many folks and I also know that Happy WIfe = Happy Life.! Do let us know what you go with!
Old Jan 26, 2020 | 05:39 PM
Martinez1031's Avatar
OP,where do you live? A little place that gets snow,freezing temps and tons of salt dumped on the roads?
Old Jan 27, 2020 | 07:52 AM
MaximusN8's Avatar
Will do Lt thank you!
Old Jan 27, 2020 | 07:54 AM
MaximusN8's Avatar
You know it Martinez, lol I live in Massachusetts!
Old Jan 27, 2020 | 10:50 AM
They are probably getting water inside. Once the temp drops,it freezes and expands. This happening over and over again will definitely make them bulge. A lot of these lugs have spaces or gaps on the inside. After you change em, save a couple and cut them in half with an angle grinder or something. See what the surprise is on the inside
Old Jan 27, 2020 | 01:32 PM
MaximusN8's Avatar
Yeah I'm definitely going to do that, Damn New England weather it's time I moved to Florida. If I could only convince the wife lol
Old Jan 27, 2020 | 02:12 PM
I’m in the same boat. I’m in Westchester County in NY. Highest property taxes in the entire country.
Old Jan 27, 2020 | 02:52 PM
MaximusN8's Avatar
Yeah bro I feel ya, you know how this struggle is every winter..lol pot holes everywhere, excessive road salt, snow, rain, ice these cars get a taste of all harsh elements!
Old Feb 1, 2020 | 09:07 PM
Maxgig's Avatar
Yeah, I had the same problem with my Maxima and my F150. The lugnuts on my truck had water that froze in them and my Maxima had the outer shell come off from a shop using an impact gun to tighten them down.
Old Oct 4, 2020 | 05:04 AM
RickSmith's Avatar
Hi all,
Thank you
I have a 2016 Maxima and had the same lug nut problem. Even if I purchased new, expensive OEM lug nuts, the problem would return in a few years. I have 40K on my car, and rotate every 5K, so my OEM lug nuts were deformed from normal use.
Dorman Products...https://www.dormanproducts.com/...makes sold, one piece chrome lug nuts that look identical to OEM, plus they are a quality product.
The cheapest I found was on Amazon, a box of 10 for $39.39, and free delivery if you have Prime. I put a set on my car, and am 100% satisified.
I'm amazed that Nissan continues to have such lousy OEM lug nuts...it is almost like they design them to be a normal replacenet item.
Old Oct 4, 2020 | 06:26 AM
98 i30t 5spd's Avatar
I have a Toyota and they use the same style lug nut. I was told it happens due to the use of an impact gun. I now only remove those lug nuts by hand and continue to use a torque wrench when putting them back on.
Prophecy99
Mar 31, 2015 08:01 AM
SleeprLegend
Jan 16, 2014 06:05 PM
James92SE
Dec 15, 2010 06:12 PM
