Running power to a trailer from the trunk
I recently bought a small utility trailer to use with my '10. I need to install a wiring harness in the car to use to run the trailer lights. Etrailers has a number of them, but they all require running a wire through the trunk floor, across the bottom of the car, and up into the engine bay.
This seems a little nutty to me. Surely there's a way to run the wire internally from the fuse box? Or pull power from anything else in the back?
This was really easy. Ran from the box down the plastic trim the rear seat, then adjacent to and behind the seat, and just behind the felt. Hard to describe, easy to do. The whole install was about 45 minutes. I have no idea why they insist on drilling a hole in the trunk and going under the car.
Sorry it's late, I did this too. Like you say, not bad at all running the wire through the car. The most bothersome part was going through the firewall. I don't tow often and have 190,000 on the car......change the CVT fluid every ~ 45,000
mtrai760
Nov 15, 2001 09:40 PM
