alternator lights turned on, then off
Had the brake and battery lights go on. Turned off the engine and turned it back on and they were off again. Tested voltage on battery with engine off and it was 12.7v, and with engine/headlights/ac/radio on it was 14.43v, so those seem normal right? Drove for a couple days and bat/brake lights have not turned back on yet.
The interior dash lights are a bit dim, and clock dims a lot when turning headlights on.
I'm suspecting alternator is starting do die, what do you guys think? I had alternator die on me once before, and I had the same issue of clock getting very dim when headlights on, once I put new alternator the clock was bright again.
By the way, how many miles can our car drive before stalling if alternator totally fails? I know to turn off all the electronics to save battery power.
Just going off what you said. Id'e suggest having the alternator tested but not just for voltage. You want to See the " Diode matrix" the Graph.
Second, make sure the thermostat housing is not leaking into it drip by drip.. This issue alone has caused many Headaches.
You could have a Ground issue, check the terminals. Back the bolts off and clean them and re snugg them down. If its going to fail, it will fail when its hott. My realistic answer is, if you think its suspect, go ahead and swap it out, and don't wait for it to leave you stranded.
When you say hot, do you mean hot weather or hot engine? And how many miles do you think I could drive if alternator fails in this car?
Thanks for your input. I forgot to mention the alternator is covered in motor oil from old leaks that have been patched, I think that's what's killing it.
I disagree, If your battery is fully charged you can make it a lot further than 3-4 miles before it runs out of juice so long as your mindful of your electrical usage (radio, hvac, lighting).
Ive had the pleasure of alternator failure on my Maxima, Pathfinder, and the wifes Murano.The maxima made it about 20 min (mileage unknown) with running lights on and headlights on intermittently, pathfinder was a good 40min (30-35 mi)with cheeks clenched and everything off.
If you want to push it, chances are you can still make it home when (not if) the alternator dies.
I'd replace the alternator now because its just a matter of time before it kicks the bucket.
RITE
Jun 3, 2021 07:56 PM
cash94
Aug 20, 2013 05:09 PM
3randon
30
Apr 14, 2013 01:20 PM
subwayhello
Feb 16, 2013 05:04 AM
goldmax
Jun 14, 2003 10:43 AM
