Tapping into front turn signals
Old Jul 13, 2021 | 08:08 AM
garrett0524's Avatar
Hey guys. I have a 2011 nissan maxima. I have a high mounted third brake light that sits on the inside of my rear windshield. I wired this light so it works as a brake light and sequential turn signals. I was able to do that by tapping into the rear headlights wiring housing, then using a multimeter to see which wire does what. My question is, I just bought some drl strips for the front headlights. I’ll drop a pic down below. I was able to use an add a circuit kit to tap into my washer fuse and have them come on and off with the car. They also have a turn signal function, but I couldn’t figure out where the wiring housing was for the front headlights in order to tap into the turn signals. Any clue where those wires would be?
This is the part: https://www.amazon.com/dp/B07K7F7KRS/ref=cm_sw_r_cp_api_glt_fabc_DXBXC4048PVBQ0DBCYN3?_ encoding=UTF8&psc=
Old Jul 15, 2021 | 02:44 PM
BlackCrimsonChin's Avatar
By rear headlights do you mean tail lights? Any reason you can't tap into the wire that plugs into the signal bulb?
Old Jul 16, 2021 | 07:29 PM
Captive8's Avatar
And by rear windshield do you mean rear window or backlight?
Old Jul 18, 2021 | 03:57 PM
I previously tapped into the tail light connections in order to wire the third brake light to the brake and turn signal connections. Now i’m dealing with the headlights, but am unsure where the wires are to tap into the turn signals.
Old Jul 18, 2021 | 04:05 PM
The wires are plugged into the headlight harness, they're right behind the headlight. Just follow where the turn signal bulb is and you see where the wires are plugged into it. It's a plug with 3 wires, looking at the plug with the tab facing up, it'll be the wire on the right.
This diagram should help you. The picture is of the headlight, so imagine the plug plugged into it to see what wire is for turn.
Old Jul 18, 2021 | 04:22 PM
perfect. This is what I was looking for. Thanks
reallywildstuff
Dec 15, 2022 10:12 AM
roman
Mar 21, 2002 02:25 PM
maximumsportZ
Jul 12, 2001 10:47 AM
