CAI lead to throttle-body leaks?
Old Feb 7, 2002 | 12:45 PM
sleepermax's Avatar
Anyone developing throttle body leaks around the seals that join it to the manifold? Reason I ask is because the stock intake has a kind of "accordion" section on the tube between the throttle body and the rest of the intake. What this does is take the stress of the throttle body when the engine "torques" around - like when you feel wheel hop. With the CAI there is no section to provide much slack - in other words the CAI is almost a solid connection between the throttle body (which moves with the engine) and the chassis which doesn't move. So there's physical stress on the throttle body because the rubber couplings used on the CAI are very rigid. I remember a couple of posts where someone was complaining they thought they had developed some leaks......
Old Feb 7, 2002 | 12:49 PM
DanNY's Avatar
Ad·min·is·tra·tor
if you're worried about it..then you need this.
Old Feb 7, 2002 | 02:58 PM
dwapenyi's Avatar
Re: CAI lead to throttle-body leaks?
Well, between the CAI's pipe and the TB are 2 rubber inter-connecting hoses. They have some give, as i've observed when I cleaned my TB. It's probably not as loose as the accordian style contraption of the stock intake, but it seems to be fine. I've had my CAI for ~50K miles with no problems.
DW
Old Feb 7, 2002 | 07:49 PM
theMax's Avatar
Good idea. May get rid of that squeaking.
where are they from? How much?
Old Feb 7, 2002 | 07:50 PM
GTRBlkMax97's Avatar
What squeaking?
Old Feb 7, 2002 | 07:53 PM
theMax's Avatar
With the CAI I get squeaking under heavy throttle. This is where the lower CAI tube rubs on the fusebox and hole. I use weather strip to stop it but it wears out quickly (I have a 5gen)
Old Feb 7, 2002 | 08:17 PM
190hpKiLLA's Avatar
Granny Driven
cheap 5th gens
Old Feb 7, 2002 | 08:21 PM
theMax's Avatar
Originally posted by 190hpKiLLA
cheap 5th gens
very nice
Actually the CAI fit is real tight. I wish there was another way to install the CAI.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Sep 27, 2015 08:37 AM
