UIM off and just a few questions.......
So I only found one bolt holding the back of the UIM to the brackets. 13mm head. NOT the Nissan size. So I went looking on Nissan and the part 08070-8161a is discontinued (I need 2)
Nissan DOESN'T give any info on size. Bastids. I know the head is supposed to be 12mm. Anybody know the length and M size and what washer or spacer is applicable?
My EGR Tube looks to be clean at the UIM mount as it was replaced about 3 years ago (the old one rotted and perf'd.), but I want to remove it and make sure the other end is clean like new as well. I have both gaskets. Is there any way to loosen that zinc plated pipe that is too close to remove the bolt or is cutting the end of the stud the only way? Mind you, the EGR tube is newer and the stud wasn't cut, so there is another way to make this happen. And probably less annoying!
Calling on you guys with the most fun experience! LOL
Thanks in advance!
Thanks in advance!
Wow JS!
Thank you for the info and offer. Local Hardware has these in Flange Head like you show in the Picture! And that is a sexy picture! If they have them in 12MM Socket size, they'll run about a $1.
If not, I might take you up on your offer!
I know it's sad that I think that's a sexy picture. But look how much missing information it has!
Thank you again! As always!
I think many of us that have had the UIM off will tell you this. I have been running my car for a couple years without either of those 2 bolts and I've had 0 issues. I must of tried for 30-40 min strait to get those back on after I did the rear valve cover gasket job and just said F it and left them off.
I agree it’s a pain. I initially was planning to swap the hoses with longer ones then upon seeing the connection with my own eyes I ended up just bypassing the whole connection with a longer section of fuel hose. Must have a purpose possibly the egr gets too hot for the manifold due to exhaust but the contact area is so tiny I said F it. Been over a year and counting.
You definitely need to saw through that stud.
There is no alternative.
I wrapped electrical tape around a hack saw blade to make a handle.
I also used a longer hose to bypass the junction at tge back of the manifold.
I stuffed some wire through that tube. I used the wire to support the hose so it does not contact hot parts of tge engine. I put bits of spare hose between the wire and the bypass hose.
The egr system is not just about that tube.
carbon will also build up in the chamber the egr unit lives in. That chamber part can be detached for cleaning. You will need the egr gasket between the egr and the housing it lives in. Possibly another gasket between that housing and the engine. My memory is a bit forgetful about what I did.
Thanks all! I'm a bit of a perfectionist, so it's all going to go back together as spec'd if it kills me.
And it might! What a PITA! LOL
As far as the two hoses that attach to the EGR, That's not as difficult if you use a typical band clamp and have the screw/bolt head facing the front of the car as you lift the UIM and get a socket with a long screw driver handle on it. Spring clamps and pliers are futile.
I am looking for Bulk Hose to replace the PCV Valve hose and the other thick vacuum lines on the same system. Anybody have any sources. Big Chain and Local guys can't match it up.
Nissan sells an OEM replacement for around $40 plus shipping for the PCV. All of 3.25 inches long.
And I'm with you JvG. Got all the gaskets and LOTS of cleaners and I'm going in Ballz deep and getting it ALL done right the first time. I might have to drive this VERY far to go visit friends in other places!. LOL
And as far as that stud goes.... I don't need no freakin tools. I use my teeth! (Jerky Boys)
So if anybody has any Nissan equivalent hose sources, please advise! Nissan sells an OEM PCV hose for around $40 plus shipping. All of 3.25" long.
Thanks Gents!
Thanks Gents!
OK guys..... What am I doing wrong?
I can't seem to get the Injector electrical plugs off the three front (2, 4, & 6 injectors. I sneeze the end of the green clip, I push/slide the green clip into the plug and it won't let go. NADA! Of course having no leverage with short wires and nothing to pry against is a real treat as well!)
Sawzall or Chainsaw?
Push the green part in towards the injector until it locks in place. It doesn't get squeezed like the older style. Once it is locked the connector will slide off. Try wiggling the connector as you push. Probably filled with dirt and such.
JS.... You didn't say whether to use a Sawzall or Chainsaw! LOL
Thank you!
I have been sliding it in probably too gently and not getting to lock in place. Didn't want to hurt it.
There's repair manuals. And then there's the twicky wabbit reality manuals. With all the secrets that prevent triple work and heartbreak.
Seems they only have written one of the two types!
As always... Thank you!
Thank you!
So I have a new Knock Sensor as the one in my car is 14 years old. And I'm already in this deep. Except on a 1999 maxima, there is more JUNK in the way. Like a vacuum advance that makes it impossible to even stick a kids hand in there. Removed one 10mm bolt but it looks like it's married to the Lower Intake Manifold. Anybody with a 99 know the recipe?
Hopefully JS did his when he restored his beauty!
Thanks Gents!
Thanks Gents!
I think you'd have better luck removing the lower manifold instead of disassembling the swirl valve actuator and linkage. If you want to remove the actuator, be careful removing the E clips. I tend to shoot them across the garage never to be seen again.
I am using a non Cali spec LIM to go with the DE-K intake so I am free to replace the knock sensor any time.
Thanks Gents!
Thanks Gents!
Thanks Gents for the exciting news! Extending the finish line of frustration, cursing and skin removal on the knuckles.
It doesn't get better than this! LOL
There is so much bad info out there saying 95 to 99 is easy. NOT. Cali Spec is such a treat too. But you guys are absolutely right! And the E clips on the arm would be a nightmare and it would still be difficult.
My uncle always said the fastest way to get something done is by removing the aggravation. It is always faster than trying to cheat. But somehow we always dread doing it right. Until I have no choice. LOL
Gonna keep going until I hit the lower oil pan!
Thanks again!
Thanks again!
KP, my brother had a term for very involved projects like this one.
I'll use the pc version. Just switch the first letter of each word in your mind.
Fluster Cluck.
I understand you might feel a bit flustered. Perhaps enough to say flock.
Fluster Cluck.
And if a flock of birds flies over, you know what can land on us! LOL
Perfect ending to a Cluck Fluster day!
OK all you deep DIY guys!
So, I have the UIM and LIM off and the insides are costed with that lovely coating from all the exhaust and oiled up air flowing through for 228K miles.
How do you, those that go the extra mile, get it all clean inside and out, and accomplish that without a parts washer big enough to accommodate these?
And if I have the 99 Cali swirl valve system, will cleaning this submerged destroy the diaphragm in the vacuum advance unit?
Experienced recommendations appreciated! I want her to be all pretty inside and out again! LOL And even more importantly, run the best it can and be reliable!
Also, waste handling if any major volume is used!
And one more thing.... I cut the tip off the back EGR tube stud. I can't get a wrench on the nut, there's so much stuff in the way on my 1999 Cali spec. Any secrets I'm not privy to?
Thank you!
Thank you!
Glad I can help make your watching over us more enjoyable! But it's really easy. No competition!
Just cause we're cursing and frustrated fixing so many of these issues, doesn't mean we can't have a good time being miserable!
Kerosene and Dawn? What if I prefer Ginger? (But Dawn would be my pick in an instant) You are a mad scientist! But I like that! Do you make reserve whiskey with the waste? LOL
Craig said he used Muriatic Acid on one EGR thread. Fascinating Captain!
What is world coming to?
A big container, some hot water, and de-greaser like Purple Power.
If it is really stubborn stuff use brake cleaner first.
Spray it dry with compressed air to dry if need be.
How do you dispose of that?
How about Simple Green Pro HD Heavy Duty cleaner/de-greaser. Safe for use on food prep areas. (Safer for environment too)
Maybe a pump to keep it circulating for a few hours too. I'd love a big heated ultrasonic setup! But I don't even have a garage! I'm moving next to YOU!
Immerse both the LIM and UIM?
Any tricks to getting that back nut off the shortened stud for the EGR tube?
Thanks again as always!
JvG makes whiskey. Sells it to the locals! LOL
I dispose of the concoction just as I do engine oil.
Once I'm done it's still 90 percent hyrocarbon.
I would not immerse the manifolds on it.
You could pour in some brew, swich it around, scrub the inside with a bottle brush.
Then blast it out with a garden hose.
Before you are horrified..... Engine Brite engine cleaner is nearly the same formula.
People clean engine with it all the time. They rinse it off into their street or driveway.
the kerosene residue will evaporate. So will the detergent.
by the way, jet fuel is mostly kerosene as well. The amount of fumes my method generates is insignificant compared to what an airplane spews in a micro second.
Regarding a rubber diaphragm in the manifold.
My kerosene solution would ruin it.
I would clean the outside of the manifold with kerosone. Not the inside to that diaphragm.
I learned how to work on small engines in th late 1960s.
We washed out parts in kerosene. Normal practice back then.
Some people still wash parts in gasoline.
I won't because I don't want horrible burns.
PP works better than SG which is still good stuff. I have not tried the Pro HD. I figure just clean the parts like a sink full of dishes. A bottle brush would be great.
Having trouble with the stupid stud that needs to be cut?
JvG... Thanks for the real experiences! I remember when I was young and people putting some kerosene in with the oil before changing it to remove sludge!
The Whiskey story was so much more fun! LOL
Yeah, I can't get a wrench on the nut. And I did already cut the tip off the stud. So much everything in the way!.
Did you get the nut off from underneath? Does not look like there will be any skin left on my arms!
This epic task exceeds the "fun" of replacing the water pump.
Now you know why advised you to do this during fall.
Old man Murphy would cause a rear fuel injector failure in January.
So I am ready to reinstall the LIM. All cleaned and fuel rails and all new components done and new LIM gaskets.
I also replaced the Knock Sensor with a Standard Motor knock sensor. In removing the old one, the plug seems to have been compromised and doesn't lock on to the new one.
Any ideas on how to secure it so it doesn't ever back out? Or can I trust it to STAY where it belongs?
Thanks Gang!
Thanks Gang!
Thanks Gang!
Thanks Gang!
Unless that harness 'clicks' into place on the KS, I would not move forward...
Maybe an OEM knock sensor came with different locking hardware. But everything Standard Motor makes is usually right there with OEM.
So I wound up wrapping a nylon zip tie around the back of the plug where it's narrower and then made a big loop to it and went over the knock sensor and pulled it tight so it can't back out!.
I tugged hard and it ain't budging!
Another day of creative auto mechanics! LOL Like I'm in Cuba almost! I can already smell the fresh pork, ham, Swiss and pickles in a wrap.
Almost spit out my Mountain Dew when I read that. I always enjoy your sense of humor in your posts.
