Maxima Loss of Power
Old May 8, 2022 | 02:27 PM
Daddyray831's Avatar
Charged battery until fully charged. The voltage read roughly 12.00 volts. I started the car while the car was running it was putting out over 14.00 volts. I never turned the car off. Left it in a normal idle state. I dont turn on anything. Voltage is constantly being checked. It was now only putting out a little over 11.00 volts. After about 10-15 minutes cars voltage drops to roughly 7 volts. The battery light, ABS light, and traction control light turn on. Car begins to sputter as if losing power then it eventually dies. After that the voltage is below 7 volts. Fully charging the battery and doing it again will repeat the same results.
Battery Is new. Less than 1 month old. Have replaced the alternator twice in the last 2 years. The 2nd alternator was dealership replaced. Car doesnt register any codes while doing this.
Anyone experience this scenario?
Ray
Old May 8, 2022 | 04:29 PM
Richard66's Avatar
Sounds to me your alternator is bad or the alternator wiring or connections are bad . Think back to the first time you replaced the alternator, what was the reason?
Old May 9, 2022 | 07:14 AM
1st time was a little over a year ago. Alternator was replaced because it was failing. i pirchased the alternator at AZ and took it to a mechanic replace it.
2nd time was recently. It was replaced because of this current issue and the dealership couldnt figure out what was wrong so they suggested we start there.
Issue continued after. Then I replaced the battery because that was the next thing. Now I'm attempting to figure it out because I'm already over 1300.00 into it. Through mechanics and the dealership.
Old May 9, 2022 | 07:50 AM
Richard66's Avatar
Where did the second alternator come from? Was it new or rebuilt?
Old May 18, 2022 | 06:07 AM
Dealership replaced it. I assume it's rebuilt.
Old May 18, 2022 | 07:50 AM
Richard66's Avatar
Is there any warranty on the dealership installed alternator?
Old May 30, 2022 | 03:21 PM
japonicadunbar's Avatar
I'm having this same issue. Any solution yet?
Old Jun 4, 2022 | 01:04 PM
No solution yet. I thought it may be a grounding issue but I grounded the negative cable and it still does it. What have you tried so far??
Old Jun 4, 2022 | 01:54 PM
Costee's Avatar
Sounds to me your... alternator wiring or connections are bad .
Have you looked into this? Have you checked the cable between the alternator and the battery? It might need replacement.
Old Jun 5, 2022 | 10:10 PM
I'm actually trying to find the cable. It's something like the EGI harness or something like that. I believe it runs around 1k. But I'm looking for it at pick and pulls and junkyards. Anyone have any info on the exact cable name or if I'm correct in the name?
AMP_01
25
Jul 6, 2024 04:54 PM
hamimp
Jun 5, 2007 09:35 AM
Killah Kane
Jan 13, 2007 01:29 PM
Yellowbrother
Aug 10, 2001 07:57 AM
JDwyer2821
Feb 20, 2001 08:07 AM
